Question about Vicks V150SG 1.5 Gallon Warm Steam Vaporizer
Black chunks and water after use of V150SG Vicks Steam Guard Vaporizer.
From the beginning of use, I've noticed that each morning, my water is tinted black with some chunks or "shavings" of black stuff. I finally took it all apart today and it looks like it's coming from the black metal prong time things that I assume to be the heatsource. Is this normal and/or a concern?
    Top Expert:
  • Vicks Master
  • 43,969 Answers
The black specks could be caused by interaction between the heating element and mineral content in the water.
Posted on Mar 25, 2014
SOURCE: my vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Posted on Dec 07, 2008
SOURCE: Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
SOURCE: Vaporizer That Works?
Thanks MStout
We use our Vicks vaporizer infrequently and lost the instructions. We substituted Morton (iodized ) salt. It vaporizes great now. It's so helpful to have an online resource like this.
Posted on Dec 23, 2008
My vaaporizer only runs about 4 hrs and remains full-worked that way since day one. Feel like wasted money as bought a second one and the same thing. What is wrong with the #V150 SG 2UPC vaporizer?
It should run for 18-24 hours and shut off when you run out of water or you have a buildup of calcium on the heater Empty it and put fresh water in it and add a pinch of salt to the water. try that
Feb 20, 2015 | Vicks V150SG 1.5 Gallon Warm Steam...
Is a kaz water tank leak under warranty?
I doubt if there is any warranty on this now. It has been over three years ago.
May 18, 2017 | Honeywell Humidifiers
Carpet is tinted black and black film on everything
You do not say what the device is that uses the carbon filters but if air passes through it the carbon may be blowing into the room. It also is possible that dirty air is passing through the filter without being cleaned.
Mar 25, 2014 | Hamilton Beach 04922 TrueAir Replacement...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
There are black chunks of like a stone like substance in the water after use. It is cleaned out every morning. You can shake the core unit and little chunks will fall out of the hole at the bottom of the...
These are just the minerals in the salt and water that are burned off during evaporation. It is normal. I have very hard water here and it leaves quite a mess in there.
Feb 28, 2011 | Vicks V150 Humidifier
Why is my humidifier forming black percipitate in the tank? how can i remedy this
The black particles are pretty common. This is a byproduct from minerals in the water and is normal.
Just clean the tank regularly (with diluted bleach). The black particles will also collect in the steamer unit (the top blue part). Wash this out with hot water (no soap or anything) after each use. If you tap it a few times on the floor of your bathtub you'll probably see some of this black stuff come out. No worries, just rinse again with hot water.
There's no harm from the black particles.
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I duct taped a crack in the water tank but water was deep on the floor this morning. What's wrong?
I am wondering if the floater is sticking. I have the same problem and there is no crack like others have mentioned. But when taking it apart I noticed the floater which is the piece that sticks up from inside the base was not easily moving. Taking it out tonight after work and cleaning it along with the filter.
Feb 17, 2011 | Honeywell QuietCare HCM-630 Humidifier
Vicks V150SG 1.5 Gallon Warm Steam Vaporizer Logo
403 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
