Question about Garmin GPSMAP 295 GPS Receiver
Garmin GPSMAP 295 won't acquire SAT signals
My GPS 295, which has worked wonderfully for years, suddenly won't aquire SAT signals. It powers up normally, goes in the acquisition mode, and never shows a sign on any signals. Later offers the SIMULATION MODE, which works good. Have peeked inside and see nothing out of order that could have such an effect.
Any help?
  • garryg24 Jun 15, 2009
    Thanks, will give that a try pronto.
    Garry Grofcsik
    Well, haven't tried it yet. Not sure why the nudge to accept the solution so quickly. I'll have a chance to try it within a few hours. Suspect, however, that the unit is busted. I have used it off and on for years ferrying airplanes. It's never even burped, even it it was neglected for months at a time. Also, don't have AC adapter, use batteries or plug to 12V DC aircraft power on various aircraft, big and small.
    Brigadier General:
  • 8,619 Answers
Hi
If the GPS has not been used and allowed to acquire satellites within the last three weeks then follow these steps:
1. Plug the GPS into a wall outlet with the unit on and allow it to charge for eight hours
2. Perform a satellite reset: Start with the GPS off, a good antenna, and a clear view of the sky. Press and hold the ‘Out’ button then turn the GPS on using the ‘Power’ button. Continue to hold the ‘Out’ button until the “I Agree” message appears on the GPS. Release the ‘Out’ button and allow the GPS to acquire satellites for at least 15 minutes.
If the GPS is used on a regular basis but continues to show the incorrect date and time after power on then follow these steps:
1. Update the operating software to the latest version through www.garmin.com
2. Plug the GPS into a wall outlet with the unit on and allow it to charge for eight hours
3. Perform a reset: Start with the GPS off, a good antenna, and a clear view of the sky. Press and hold the ‘Quit’ button then turn the GPS on using the ‘Power’ button. Continue to hold the ‘Quit’ button until you see a message on the screen about deleting user information. (If you have not backed up the user information and want to do so you will need to download this information prior to completing this reset as the reset will delete user information.) Release the ‘Quit’ button and highlight the “Yes” and press the ‘Enter’ button.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 15, 2009
  • Rylee Smith
    Rylee Smith Jun 15, 2009
    Hi Pronto
    I believe this will resolve your issue so please do accept the solution and revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Sorry for the misspelled name Gary.
How to set time and date on GPSMAP 295
Set the time zone and daylight savings according to the instructions on page 76 of this manual. The time and date are automatically set from the information received from the GPS satellites.
Jan 28, 2013 | Garmin GPSMAP 295 GPS Receiver
GPSmap 296 doesn't show any satellite signal
Check that the date shown on the unit is correct. If not, choose autolocate and allow about 10 minutes for the unit to find satellites. If this works, then the internal lithium ion battery is defective.
Jun 02, 2010 | Garmin GPSMAP 295 GPS Receiver
NO BATTERY POWER,ONLY EXTERNAL SOURCE
check contacts inside the battery compartment are perfectly clean and install NEW batteries (alkaline good quality). If remains the same problesm, needs to be repaired at Garmin´s shop
Mar 17, 2010 | Garmin GPSMAP 295 GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
296 takes forever to acquire satalites.
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
Sep 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Battery power trouble
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jan 03, 2009 | Garmin GPSMAP 295 GPS Receiver
Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
Garmin not acquiriing satillites
hi
possibly the unit is set to 'use with gps off' mode
go to the satillite page and hit menu
select use 'gps on' then enter
make sure you let it re-find the satillites again before you move off
D
Nov 20, 2007 | Garmin GPSMAP 60CS GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
