Question about Canon Selphy Cp-800 Dye Sublimation Printer - Color - Photo Print - Desktop
Heat transfer mug without coating
Is there anyway to heat transfer on a mug without the mug being coated
    Scholar:
  • 75 Answers
Hi!
Sublimation Printing is the most common printing method on mugs. By theory, sublimation is offset printing from a transfer paper to your substrate (which is your mug). Mug Coating is important since the coat is composed of Polyurethane paint which is where the Sub-Inks adhere into. Without a Polyurethane coat, the Sub-Inks will not stick to the surface of the mugs. What you can do in order to print on non-coated mugs is to coat those mugs yourself using Polyurethane paints that you can buy at hardware stores. These are usually used in automotive painting and may cause you a bit for each can.
You have to remember though that Polyurethane paints dries longer than enamels and prolonged exposure to these types of paints is hazardous to your health.
It would still be best for you to look for pre-coated mugs to save on production time and, well, efforts.
And yes, I have tried the above tricks personally as I am also engaged in crafts business...
Posted on May 05, 2014
Which tectyl is suitable to protect an aluminuim radiator around salt water?( fitted to a 1971 landcruiser)
Because aluminum typically develops an oxide layer it is not necessary to coat it with anything. On both coasts cars and trucks are and have been used for many years with no thought of coating them. If anything the additional coating would probably just restrict some of the heat transfer to the air.
Mar 06, 2015 | 1971 Toyota Landcruiser
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
Jun 07, 2013 | Home
How high should I mount my coat rack?
You should install your coat rock at the height that iseasiest for you to reach, without having the coats touch the floor. For most adults this is about five feet high.
May 29, 2012 | Home
I bought the Ducane Affinity 3100 from Ace Hardware in 2009. The paint on the inside of the grill lid has started to bubble, peel and fall off. Is this covered by the manufactory warranty. Is it still safe...
According to the Owners Manual for your and the reading of the Warranty, No the paint flaking under the grill hood is not covered under warranty (see link below). As far as safety of using it is concerned ... only if you clean all the flaking paint and any residue, and repaint it with High Heat Grill Paint. This should only be applied after all greasy residue has been removed and only in light coats. Several light coats, in fact. It should be allowed to thoroughly dry between each coat, before applying the next coat. Once the final coat is applied, wait at least five days before using the grill. Be sure no paint gets down of the cooking grates or the burners. You can get the High Heat Grill Paint , form the same Ace Hardware store you bought the grill from. I believe Ace carries Krylon, which is one of the best High Heat Paints.
Apr 10, 2011 | Ducane Affinity 3100
Peeled beater and hook
Stan. If you were to keep these attachments soaking in alcohol (rubbing) between uses, I'd say yes, however this would probably make more coating flake off. This coating goes into the food you're mixing. Bacteria will remain between the metal part of the attachment and the plastic coating,where you can't scrub it off.
Replace them. Try to find all metal ones. While you're at it, throw out all cracked plates and coffee mugs too, as these cracks harbour bacteria that will survive normal dishwashing. If you are ever in a restaurant and are served food on a cracked plate refuse it and tell them not to just scrape the food onto another plate.
I spent 13 years in the restaurant business, anytime we came across a cracked plate cup or mug, into the trash it went. food and all. Dont take chances with your health. If you found this solution helpfull, please rate it Good luck. ricardok45
Jan 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Wood burning stove with integral burner not heating the water eno
When is the last time you brushed out the burner tubes of the boiler? This is how heat transfers and if you have a coating of soot, it will prevent heat transfer. check this and post me back
Dec 01, 2008 | Water Heaters
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
George
Jul 11, 2008 | Yamata PSP-990A Iron
Canon Selphy Cp-800 Dye Sublimation Printer - Color - Photo Print - Desktop Logo
88 people viewed this question
old marine
old marine
