Radio Communications Logo
N
Nakia Gadlen Posted on Mar 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio on but want light up - Radio Communications
Mike Charette
Level 3:
Genius:
  • Radio Commun... Master 1,847 Answers
  • Posted on Jul 05, 2014
Mike Charette
Level 3:
Genius:
Answers
1847
Questions
Helped
490086
Points
2211
Take a volt meter and insert one probe into the antenna socket and the other end to receive pin on the mic plug check to see if needle moves.If it doesn't you have found your problem but if it does then go to the ic and find ground.Check meter keep working backwards till you find your problem.
I have a red signal light that keeps blinking in gp328 any ideas?
A blinking red light can be a sign of the radio picking up radio frequency waves (RF) on your same frequency or a nearby frequency. There may something transmitting in your area which is causing the blinking light, or you may have another radio which could be stuck in transmit. One way to check this is to take the radio to a different location and see if the blinking still occurs.
Next, the question would be, does the radio function otherwise correctly? If so, continue to use the radio and do not concern yourself with the light. If the radio does not function properly, they you should send it to a qualified radio repair center for service.
Best regards.
Radio lights are out
what lights, the dial back lights, is it stock>?
the radios have 3 power sources
1 for radio and amp.
2: dial lamps (dim,) if the other cars dim-able park lamps work then
the radio lamps are bad, or not connected (1 wire)
3: memory. power.
my guess is the rad back lamps are dead.
so turn on the parking lights (Head ligths 1st click)
does dashlight up.? no, turn the dimmmer up.
do they light now? yes, and radio no?
if no radio lamp now, the lamp is bad or wired wrong or the fuse blew
that the dial feed wires to.
if not stock, any thing is possible, (infinity)
9helpful
Were can i find a color coded wiring diagram for a radio in a 1999 ford explorer
For 1999 Ford Explorer Car Stereo Radio Wiring Diagram check this...
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Blue
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 x 7
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5 x 7
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rating this free answer).
What is the wiring diagram for the stock radio
Check this...
1998 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ground Wire: Black/Light Green
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5" x 7" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Hope helps (remember to rate and comment this answer).
Radio lights, steering wheel radio controls, and HUD not lighting
well, this morning they are fine, all i did was checked all fuses that had to do with illumination and radio. none were bad so no replacements were made, and now it works. wish i knew what i did.
7helpful
Need wiring diagram for a 2002 mustang Mach 1 radio. radio is hooked up and working but not the bottom door speakers . need to know what color the bottom door speakers are left and right and + & -
2002 Ford Mustang Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Front Speakers Size: N/A
Front Speakers Location: N/A
Right Front Speaker Wire (-): Green/Orange
1helpful
2answers
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
1helpful
2answers
Dashboard lights not illuminating.
CHECK DASH LIGHTS FUSE.THE GUY WHO PUT RADIO IN PROBABLY FORGOT TO HOOK UP YOUR RADIO ANTENNA LEAD.GETTING NO RECEPTION WILL CAUSE STATIC.
3helpful
2003 sunfire radio display does not work, but radio does.Help?
Light is burned out in radio. You can replace the front face of the radio from a good one with a good light and put on your radio and the radio will light up and work in your car. If you replace the whole radio you will need to have the radio unlocked.
Remove your radio. Locate a used radio at a wrecker. Put your car is accessory key postion and plug in the radio at the wreckers. if it lights up it is good. Remove the bottom panel on both radios and unplug the 2 wiring plugs that come from the front face. they are side by side. Unclip the front face and plug back into your radio. Replug it in and snap the bottom back on your radio. Plug back in and it will now light up your radio.
The whole procedure should not take more than 15 minutes and all you need is a 7mm socket and a flat screw driver.
If you are more daring you can also buy a cheap am/ fm only radio with a light and replace th circuit board of the back of that one to the circuit board on your radio and use your own front face again. It willl light up and all your items will function regardless of whether the doner board had cd or not. Time on this is 3o minutes and you need a small wrench to remove the screws in the board.
Good luck. I replace about 10 on these each week so the wreckers in my locations no longer have many low end radios avalialbe either. This is the lowest cost way on fixing this issue.
3helpful
Radio lights off on 1998 ford explorer
1 -Check your head light switch and turn signal switch by taping them lightly - Common problem with fords to short signal light switch/head lights and they also have radio lights/clock lights control(lights dim for Radio/clock when you turn the lights on)
If you have checked all the fuses and switchs, possible that the light bulbs have burned out. Check with a local radio repair shop and they can remove the radio and install new bulbs.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
