Question about Sylvania Televison & Video
Sylvania tv turns on, sizzles, and turns off
Tv turns on for about 10 seconds, sizzling noise coming from the back, and then turns off! please help!
SOURCE: sizzling, burning smell, parts
I have had this problem in the past, its the diode part #160-2000-000 Got the part through Carrol Apl. 1-800-654-3545
Posted on Feb 20, 2008
centralhigh
  • 260 Answers
SOURCE: TV comes on and shuts off after about 10 secounds
This particular model has a history of this problem.
This sounds like a safety feature built into the television. It may be trying to protect itself from an unsafe electrical source. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly.
Posted on Jun 20, 2008
  • 62 Answers
SOURCE: Making sizzling noise
My Ionic Breeze GP had the hissing problem from time to time. When I first got it, I even sent it to have it replaced and the replacement unit also started hissing. Therefore I think it is a pretty common problem.
Cleaning it as described in the product's documentation and in other Fixya solutions such as this one:
http://www.fixya.com/support/t154553-ionic_pro_sizzles_crackles_when_turn
seems to help a lot of the time. Also, more frequent cleaning (don't let it get too dirty or wait until the light comes on) seems to help. However, I've had time where no amount of cleaning, blowing air, claning the wires, etc. will make it quiet.
That brings me to my point:
I recently had to take the whole unit apart after it totally stopped functioning. This had nothing to do with cleaning, but was a bad switch (my posts regarding this fix are also on Fixya). What may be relevant is that when I had the unit apart, not only did everything get a good cleaning, but I also found several dead insects that were down in the bottom part, down by the power supply components, down where you would not normally clean because that area would be behind plastic covers.
After removing the insects and blowing that area out with a can of air and dusting with a cloth, after reassembling everything my Ionic Breeze is running the quietest it has since it was new, and when it does make noise, normal cleaning makes it go away.
What I am suggesting is that maybe some of these chronic noise problems that so many people experience are due to dead bugs or dirt beyond the area that one normally cleans.
BE CAREFUL IF YOU REMOVE THOSE COVERS. YOU DON"T WANT AN ELECTRIC SHOCK. MAKE SURE THE UNIT IS UNPLUGGED AND DON'T TOUCH ANYTHING WITH A CONDUCTOR MATERIAL OR YOUR HANDS.
Posted on Oct 29, 2008
SOURCE: ssl2006 sylvania TV goes dim and turns off within 5 seconds when turned on
POWER SUPPLY SHUTTING DOWN
Posted on Dec 15, 2008
MNfisherman
  • 11896 Answers
SOURCE: sylvania 42" flat screen won't turn on
First you should check the fuse and the wiring in your tv by removing the back cover. Make sure no wires are bare or touching. If there are any, wrap them with electrical tape.
If you cannot see anything wrong by looking, then it is probably the set has a bad transformer (high voltage)
Posted on Jan 17, 2009
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Sony google tv makes sizzling sound
Even after switch off, there can be some discharge of static charges present in and around TV, hot plastic parts can contract and make some noise. Some sets have the cooling fan run for a few seconds more to reach a particular temp, before it is turned off. Just try switching off the power outlet, and removing the plug and see.
Aug 19, 2012 | Sony Google TV NSX-32GT1 32 in. LCD HDTV
I have a philips big screen tv model# 60P8342A and when I turn it on I can hear the sizzeling noise from when a tv is turned on but the screen is all black. What may be wrong with it and how can I fix it?
Do you mean sizzling from a certain area, like where the on off switch or mains input socket is, if so may be nothing more than a solder connection, If you know someone good with soldering , but be warned disconnect from mains and be careful, had a sizzling problem recently , turned out to be bed connection on mains socket.
pete
Nov 15, 2010 | Philips 42PF9431D/37 TV
I go to turn it on and it sizzles and shuts itself off.
Replace the flyback. You need the 259296 flyback replacement kit which has the flyback related capacitors and the CD with detailed instructions. The kit is available at www.tvrepairworld.com
Sep 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca 32v343t atc010a and when i turn it on the power light comes on and the tv makes a noise like its coming on but then theres no picture or sound. I would like to finde out whats causing this to...
It sounds like the High voltage transformer has gone out. If you open the back of the tv and look on the right side, you will see a large (4 - 5 inch) black cylinder with a large wire coming out of the top. without touching anything, look and see if it is cracked.
Feb 18, 2009 | RCA Televison & Video
Projection tv not working
I guess loud sizzling was from High Voltage Splitter in your TV. HV seems cracked and leaking high voltage.
You can observe and confirm it by removing back cover and power up TV from distance and check at rear of TV. Please take care and there should be little dark to observe arc from HV splitter.
If this is the case, HV splitter available in Part Store.
Dec 16, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
