Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony my sony tv is flashing red lights 6 times
Re: sony
Http:// Says something about overvoltage... Might want to call a service tech.
Posted on Nov 15, 2007
0 characters
3 Points
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Projection Televisions
Light blink 6 times
Your mainboard is gone bad, happened to my tv and they had to replace it.
Oct 09, 2012 | Sony KP-53HS30 53" Rear Projection...
Check for a repair kit on
Mar 21, 2012 | Sony Projection Televisions
When i turn on the tv the power light starts blinking red and it turns off
Hi I have a Sony KDF-55WF655 and I just installed a new lamp, now when I got to turn on the tv my power light flashes 5 green followed by 6 red flashes and continues to flash a series of 6 red flashes and has no pic, Any help would be great
Jul 13, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Power/standby led beeps red light 6 times
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv will not power up, when i turn it on the green light flashes 6 times then the red light flashes 6 times
Try replacing the projection lamp first as this is a suspect in a 6 flash error. The part number is A-1606-034-B. Please take a moment to rate my answer. Thanks..
Nov 23, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Dredded 6 Red Flashes
Sounds like you need a new lamp.
Jul 07, 2009 | Projection Televisions
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link -
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
51 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
