Monitor Cycle through colors
Monitor cycles through colors
  • 76 Answers
Sounds like it's running some sort of pixel correction process. Some monitors have a menu accessed via buttons on the bezel where you might be able to turn it off.
Posted on Mar 25, 2014
Testimonial: "Thank you for your reply. I tried what you suggested but I get no OSD on the monitor. However, I do think the monitor running some sort of process maybe correct though. Something like it's not receiving a signal so its going through this 'color pattern'?"
  • JTAR Mar 25, 2014
    Sorry, I thought I wrote more details. If not here they are.
  • JTAR Mar 25, 2014
    I thought enter would put me on a new line, nvm. The monitor I have is a Philips 191V2. The buttons on the monitor no longer do anything - no OSD shows when I press any of the buttons. I Tried other VGA, DVI cables and on diff computers. Still the same.
Philips LCD Monitor Cycle through colors
you mite need to replace the board which is in the lcd , which is quiet rare and mite even be unavailable,
Mar 25, 2014 | Computers & Internet
My monitor has gone a bright blue
Check the pins in the end of the monitor cable, look for bent ones. If it's okay re connect to the monitor and try again. Unplug the monitor and wait for a few seconds, plug power back in. Cycle power on the monitor. Then restart your computer. Wiggle the monitor cable on either end and see if the color changes.Good luck
Sep 30, 2012 | Microsoft 66I-00752 WINDOWS VISTA -...
What is the drive cycle after changing the catalytic converter on a 2001 pontiac grand prix
there is no drive cycle, just get in and go. But if youre asking for the cycle on the readiness monitor for the CAT. it will take several drive cycles for that monitor to run to see if the new CAT. passes or not.
Apr 25, 2012 | 2001 Pontiac Grand Prix
Can u uninstall emachines then reinstall so that the colors are right
1) Right-click on an empty area of your desktop screen.
2) Left-click on Properties at the bottom of the list.
3) Left-click on the Settings tab.
4) In the middle on the right side; What does it state for Color quality?
It should state - Highest (32 bit)
If not left-click on the blue down arrow to the right of this box.
(Color quality box)
Left-click on Highest (32 bit)
Now go below to the right, and click on Apply.
Then go to the bottom left, and click on OK.
Still no change?
Go to your monitor, and monitor settings. See if the colors are set right.
Still no?
If the monitor is a flat LCD screen, see if there is another KNOWN to be good monitor cable, (From another computer?), to use for a test.
If you are using an older CRT monitor, it may be at the end of it's 'Life Cycle'.
(Looks like a small TV)
Regards,
joecoolvette
Jan 20, 2012 | E-Machines eMachines Desktop PC
Some of the colours are missing from my printing
In all likelihood your ink is running out. If your print monitor reports that you still have ink remaining in the colors you are missing, the issue is probably just a clogged print head. To clean your print heads, first insure you have paper loaded into the feed tray on top, press the "Menu" button on the face of your printer then press the down arrow until you see "Clean Cartridge". Select "Clean Cartridge" and wait for the cleaning cycle to complete. If the colors are still missing after running the cleaning cycle 3 times, you will need to replace your color cartridge. Low cost replacements can be found using a web search or visiting your local office supply store.
Nov 25, 2010 | Lexmark P4350 All-In-One InkJet Printer
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
What is drive cycle miles to make ready emission test on ford f150 5.0 engine?
a drive cycle is not measured in miles driven but in the type of driving done, here is a ford drive cycle procedure to clear the not ready code.
Ford Motor Company Driving Cycle Description of OBDII Drive Cycle
The following procedure is designed to execute and complete the OBDII monitors and to clear the Ford P1000, I/M readiness code. To complete a specific monitor for repair verification, follow steps 1 through 4, then continue with the step described by the appropriate monitor found under the "OBDII Monitor Exercised" column. When the ambient air temperature is outside 4.4 to 37.8°C (40 to 100° F), or the altitude is above 2438 meters (8000 feet), the EVAP monitor will not run. If the P1000 code must be cleared in these conditions, the PCM must detect them once (twice on some applications) before the EVAP monitor can be "bypassed" and the P1000 cleared. The Evap "bypassing" procedure is described in the following drive cycle.
The OBDII Drive Cycle will be performed using a scan tool. Consult the instruction manual for each described function. NOTE: A detailed description of a Powertrain Control Module (PCM) Reset is found in this section, refer to the table of contents.
Drive Cycle Recommendations:
  1. Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
  2. Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
  3. The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
Jun 05, 2010 | 1996 Ford Explorer
AOC LM725 Color Cycle
AOC brand are disposable, now if your going repair its chips, its definitely work or not... i tell you this monitor is very deliquate to work normally.... buy a new one...
Jun 16, 2009 | AOC LM729 17" LCD Monitor
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Monitor cycles through various colors
Sounds like some sort of static effecting it but i doubt it, youve checked your'e wires but if it's a graphics card have you checked the card it may need re-seating, also check connectors for bent pins.
Nov 03, 2006 | Acer AL1512BM 15" LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
