It seems you have been infected by a trojan. This virus infects all versions of WIndows OS: It is considered a Low Risk Virus, but it needs to be removed immediately.
Backdoor.Ranky.Z allows unauthorized access on the infected pc
by opeing a backdoor port.
Technical Name: Backdoor.Ranky.Z
Lets Remove the Virus:
- Disable your system Restore; this is to keep the virus from restoring itself to do this:
- Right click on my computer
- click on properties
- select system restore tab
- check "turn off system restore" uncheck "to turn on"
- click Apply
- click Yes when dialog box tell s you this will erase all restore points.
- Press OK
2. Make sure your virus definitions are up to date.
3. Reboot your system in Safe Mode
4. Run a full/deep system scan & delete all infected files.
5. Delete/Modify any values added to theRegistry
how to edit registryDelete this entry :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
\"Advanced DHTML Enable" = "[PATH OF TROJAN EXECUTABLE]"
6. Exit registry editor and restart your PC.
7. Run a Full scan to make sure it is really gone.
Hope this helps (rate high if this helps)... Good luck! ^_^
