Question about Samsung DMR77LHS Tall Tub Dishwasher
Water won't empty
It fills with water and then quits. blue lights on "heavy and quick" come on and it won't empty or run further
I pulled the dishwasher , on the left side if it about halfway back down near the bottom you will see a plastic resovoir like , it has two hoses hooked to it , I took it off being careful not to break the seal, then I used a pipe cleaner to get the crud off of the float that is inside the flat looking plastic container . it works like a champ now !
Posted on Mar 26, 2014
The Heavy and Quick lights are blinking
If it is a Samsung, which I imagine it is, then you have too much water getting in to your dishwasher during the fill cycle.
The two most common reasons for this error are: 1) too high of water pressure for your house (it should be about 50 to 70 psi, or thereabouts---Note: You'll need a plumber to fix your PRV valve if your water pressure is above 80 psi) or, 2) your water inlet valve on the dishwasher is bad and letting too much water come in during the fill cycle.
Try to reset the error by turning off the circuit breaker for your dishwasher for about 5 minutes, and then turn it back on and see if that clears out the error. Then, try running another load and if you get the error again, check your water pressure and your water inlet valve.
Oct 24, 2014 | Dishwashers
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Filling up with water
Jimbo, you are going to need a new inlet valve. This is very easy to change out. Remove the 3 torx screws in the back for the top. Slide it off toward the back. The valve will be on the inside top left. Two quick connect harnesses, a couple of hose clamps and your done. I don't have the part number on hand but you can find it on the tech sheet located behind the bottom panel. Three screws to take that off. Or you can go to repairclinic.com, enter your model number and hunt it down from there. Once you change the valve, your leaking problem will be over. Catriver.
Dec 19, 2007 | Kenmore Elite 45986 Front Load Washer
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
WATER FILL LEVEL
Every cycle has its own water measurements for example: Heavy Wash : 7.2 gal. so check the manual for further information. And don?t worry there is an Overfill Protector, so you won?t do any damage. Good luck
Apr 01, 2006 | Frigidaire 25 in. FDP750RC Free-standing...
Samsung DMR77LHS Tall Tub Dishwasher Logo
50 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
