Question about HP Compaq Presario R4000 Notebook
Slow start up and beeps a couple of times
System starts but then seems to stall on lauching. a couple of beeps occur
  • 247 Answers
The beep pattern tells you what is wrong. Search Google for the exact pattern...ie 2 short beeps, 2 long beeps, etc. Could be bad RAM chip or bad motherboard or video card, etc. The beep pattern will tell you what needs to be fixed.
Posted on Mar 25, 2014
O7 rhino 660 runs good,then backfires and stalls.starts every crank,but will run short time then stalls.does not backfire everytime.seems like it runs longer when it sets couple of days.
I would overhaul the carby and check for corrosion in the main jet and other circuits
if it is a 2 stroke I would check the crank shaft seals as they may be hard and leaking mixture and running lean ( backfiring)
Oct 11, 2015 | Rhino Motorcycles
I have a 2003 CR-V. Tonight I left the lights on and it drained the battery. The battery is only a couple months new, so with a quick jump, it started immediately and ran, seemingly with no problems.......
your battery may not be fully charged yet with the quick jump. let it run for a bit with no lights or accesories, no a\c or heat. everything is run off the computer and it need to be fully charged.
Jan 09, 2011 | 2003 Honda CR-V
Engine stalling
My 2000 accent will stall only when hot and will not start till it cools down.
Apr 12, 2010 | 2000 Hyundai Accent
Start the bike runs good starts to miss then stall wait a coulpe
Because the problem you describe is intermittent, it is almost certainly fuel related, either the fuel itself or the carbs on your bike.
Before taking it to a dealer or mechanic (or trying to fix it yourself), get a can of Seafoam (I know Autozone has it) and add it to the fuel. It seems to do an excellent job of cleaming out whatever bad stuff accumulates in fuel systems over time, especially carburetors.
There's an interesting review of it at: http://www.webbikeworld.com/sea-foam/
Aug 02, 2009 | 1994 Honda CBR 600 F(2)R
My (1999) Saab 95 (2.3 litre) engine cuts out without warning. This tends to happen after slowing down. It immediately re-starts as if there had been nothing wrong and functions perfectly otherwise. The...
the iac valve on the throttle body is maybe sticking and the idle speed is to low.that will affect the power steering pump.the air filter has to be clean otherwise the mixture will lean out because of reduced airflow and stall
Jun 13, 2009 | 1999 Saab 9-5
1996 Toyota Camry Stalls when slowing down/stopped
Your carb may need cleaning. I had the same problem with my Astra. If not then there is too much air getting into the engine.
Jun 05, 2009 | 1996 Toyota Camry
06 dyna won't start
Check your spark plugs. If they don't have your injector mix right, you could be fouling plugs...
Jan 07, 2009 | 2006 Harley Davidson FXDLI Dyna Low Rider
2003 GMC Sierra Stalls at low RPM
I had the same problem with stalling when slowing down or coming to a stop . Check engine light coming on also . fixed my problem truck now runs like it did when i drove it off the lot in 03. Go get a couple dollors can of Carb Cleaner. take duct work off of Electronic Throttle Body and spray it completely let sit couple seconds and repeat this time take an old toothbrush and after spraying scub infront and around throttle clapper and rerinse with cleaner let air dry and put duct back together . this worked wonderfully for me hope does for you
Dec 08, 2008 | 2003 GMC Sierra 1500
2000 grand cherokee v8 struggles to start and stalls when slowing
i think your exhaust might have a leak which is heating up your oil when this happens the engine suffocates and wants to die.
Dec 02, 2008 | 2000 Jeep Grand Cherokee
Computers & Internet Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
