Dewalt DE0245 battery charger blink fast without battery inserted
This charger once power up, without battery inserted its blink very fast like normally these charger blinks when battery inserted in to it but there is no battery in the charger just plugged in to mains and its start blinking as shows the battery is fault
  • 27 Answers
It really sounds like the electronics in the charger are failing or failed, it's probably cheaper to buy a new charger
Posted on May 13, 2014
  • 44 Answers
SOURCE: Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Posted on Sep 19, 2007
  • 81 Answers
SOURCE: blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Posted on Nov 30, 2008
jvernice
  • 63 Answers
SOURCE: my acer 5100 blinking power light
The battery needs to be replaced.
Posted on Jul 30, 2009
rulds2008
  • 3866 Answers
SOURCE: I have a DV9000 17" Notebook, power led blink three times
Okay the logistics here of this laptop that would be normal for the power light not to come on without battery in place REASON? Because this laptops primary source is battery secounary source AC power.
A Blinking light and no boot means a hardware failure. I would need to personally look at it to tell you 100 percent what is the cause but I would rather you take it to Best Buy and have them do a full eval on it for under $50 bucks if there is something really wroung they can follow up with a warranty claim.
Posted on Sep 23, 2009
SOURCE: I have Dell Latitude 100L. Does not power up.
Try removing the modem, right next to the min-PCI.
Posted on Nov 06, 2009
Dewalt charger blinks rapidly shortly after inserting battery for recharge
The battery has a damaged cell or a loose connection inside. Also if u have another battery check it in charger and if the same happens with it then its a problem with the charger.
Aug 18, 2017 | Dewalt Drills
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Light flashes fast on dewalt 0245
I believe the battery can no longer be charged.
Aug 31, 2014 | Drills
Dewalt 30 Minute Fast Charger does it work in uk 230v
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Jun 22, 2014 | Drills
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
I can,t charger my dewalt batteries , so is the fault with my charger
It is likely the fault is the battery and not the charger. To confirm this take the charger to any Radio Shack and ask them to test the charger or if you have a small meter do it yourself, the charging voltage will be up to 5 volts more than the rated battery voltage of the drill, so if you get a high reading don't worry about it. Fast charger will be way over the battery rating, also fast chargers have a cost, they shorten battery life due to heat. I have had many battery powered tools, I have found that the batteries last about 2 years on average. I have this same Dewalt drill driver.
Nov 02, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Oct 07, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Batteries will not charge. charger is not recognizing battery is inserted. charger light goes from flashing without battery to no light at all when battery is added? kit is new as of thursday help!
I had the same problem with many dewalt tools. The problem was with the charger. The charger had this strange behaviour before it was used. Dewalt replaced the charger free of charge.
Sep 18, 2010 | Hitachi KC18DHL 18Volt LiIon 2 Tool Combo...
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Have just got the Dewalt DE9116 charger.Plugged it in & red light comes on & then goes off.Is the charger working properly?Have no instructions
that is normal it happens when u plugged and unpluged. after a second it should show no blinking. then when u insert the battery pack it would show the diagnostics. with the blinking pattern.
if you need the manual , you can get at www.dewalt.com or call us at 407 657 0474 and we can fax it to you.
Sep 23, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
