Question about Apex Digital AT2708 27" TV
My tv as a red key and can only open and close tv
I can only open and close tv and we can pnly har the tv but cab't see it ......what sould i do to fix it?
I need a COLOR wiring harness diagram for john deere la130 riding landowner. i do not have manual. need to know if im missing any parts. i need to know where the colored wires go. -red -red & black...
ok i found a picture diagram for what looks like to be your harness but i you need to get the numbers off the wireing harness its self
these can be very helpful in locating the proper diagram and wireing instructions for this harness
now the pictures and color codes is on a picture at bottom of the link i put in here so hope the link helps youll have to zoom the pic
there is two types of harnesses with the four points (meaning ends)
one is for the clutch and one is for back panel behind steering wheel the guages red is always hot red and black striped is key accessorie hot
yellow is usually the on position once key starts to engage blades or clutch
the blacks are grounds
need a good pic of this harness with out hand in way and closer but showing all the end points ive worked on these but i would rather see it better with more pics if possible
Nov 09, 2013 | Cars & Trucks
I have no new text message, but there is a red number one showing me i have a new message
you sould close the message from multitasking and then open it again. work for me 100 times
Sep 19, 2013 | Apple iPhone Smartphone
I have no power to the dashboard in the bob cat after door was opened with the bucket up
Blown fuse. Short in wiring to cab door. Unplug door harness replace fuse a be careful not to damage door with loader arms until you get new door harness it will not know if door is open or closed
May 09, 2012 | Bruder Cat Skid Steer Loader
The key doesn't unlock the door from the outside on 2003 ford f150. passenger door lock works. all power lock work from inside. What piece is damaged?
I would think the rod from the key cylinder to the door lock mech is off or broken.
These are pictures from when I put the keypad on my 2001 SuperCrew. The mech could be slightly different, I do not recall if this is different on the SuperCrew vs the SuperCab or Std cab trucks.
Viewed through the door panel opening ( key cylinder already out, you can see the opening rod is straight up by the red )
You can see the rod connected to the key cylinder in the upper left of this picture, down to the door lock. This is what you need to check.
Close up of the rod attached to the cylinder
This is a better shot of the key cylinder. The spring clip is removed from the cylinder, that is why it is free in the door. Take note of the way the rod attaches to the cylinder. This is plastic and could be the cause of your symptoms.
This is where I would start considering the door works as normal with the power locks both inside and out.
Sep 11, 2011 | 2003 Ford F150 Regular Cab
F150 1997 v8 , blower vent will only blow out the windshield not ant of the vents. also it will only blow cold air. i replaced the switch that controls the flow direction of the air. but still same...
Check the stepping motor that move the doors, it is the little white box at the bottom of the environmental station it opens and closes the door, when you remove it you can hook it up to the harness and operate the temp control see if the motor turns, if not verify power at the harness connector if there is power there then replace the motor. Hope this helps, let me know.
Jan 14, 2010 | 1997 Ford F150 Regular Cab
NO VIDEO
this happen pnly if your power suppy unit in your tv is not working properly, so kindly check your tv's power suppy unit.. thank you.. plz rate me..
Jun 28, 2009 | Samsung LN-S4051D 40 in. LCD Television
Peugeot Expert van Alarm
i have a new van but need to remove dent in bumper
Jun 12, 2009 | 2006 Peugeot 604
PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD BUT BUTTONS DONT WORK ON CD EITHER RADIO DOES NOT WORK AT ALL
hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
Jun 08, 2009 | Car Audio & Video
Constant power doesn't seem to be working.
you sould have the red and yello wire connected together is you are not using a factory wiring harness adapter this means you might have wires crosses
Dec 05, 2008 | 2003 Subaru Forester
Apex Digital AT2708 27" TV Logo
19 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
