Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Blue parrot cannot find my contact list
I cannot use my voice dial on my blueparrot. It does not understand my commands.
I am having problem on finding and setting voice tag for contacts.
GOTO CONTACTS
EDIT CONTACTS
EITHER IT WILL BE THERE AS IN OPTIONS
OR IT WILL BE THERE IN SETTINGS
Feb 05, 2011 | Nokia 6720 Classic Cell Phone
When i connect my veiwty to my parrott i can make calls if i use the phone but if i go to phonebook on the parrott it wont bring my contacts list up can any one help
change the parrots phone book settings to use the parotts phone book. you will have to wait 5 minutes for the phone book to load then program your voice commands.
Apr 04, 2010 | Parrot Hands-Free Car Kit with LCD Display...
Cannot pair up n95 with parrot ck3100
you willhave to send the contact manually to the parrot you can try making all but if this dont work you will have to send them one by one.
Oct 23, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot v508c
Turn off key word voice prompts/voice commands. The Parrot is listening for key words like "phone" or "call" or "hang-up". When it thinks that it hears this it will beep, or call someone.
Sep 06, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
VOICE DIALING
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Feb 19, 2009 | Motorola Mobility RAZR V3
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Problem with voice commander htc P3300
its a common problem with voice commanders...as one cannot expect a low end processing device to process your voice with 100% accuracy...even the best of best voice processors that run on high end computers are about 80-90% accurate...I suggest you reinstall the voice commander and re-create the voice tags...
Apr 23, 2008 | HTC P3300 Smartphone
Voice Dial
I had a problem getting the voice dial to work on my K1 phone. The voice dial would not work if the contacts are stored on the sim, once they are copied to the phone memory all wored fine.
Dec 27, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Voice Dial
try setting the contact in the phone and not on the sim and see if this makes a difference?
Dec 03, 2007 | Motorola Mobility RAZR V3
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
19 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
