Question about Hearthware Home Products Nuwave Pro Infrared Oven
Plastic top cracked
Need to replace top cracked
I have a toyota avalon 1998 and I have a crack in the plastic part on top of the raditor can i just replace the p;astic top or do i have to replace the radiator
These day its cheaper to simply change the rad and always verified the reason of the crack tank simply old age ,bad thermostat fan doesnt start engine overheat to mush pressure in the engine and the weak parts break first
Mar 29, 2015 | 1998 Toyota Avalon
Cracked radiator
A good rad shop should be able to plastic weld it
Mar 10, 2014 | 2005 Jeep Liberty
Sealed radiator on top - radiator hose has blown off twice - not overheating HELP
aluminum radiator
plastic top and base seal
tanks held in with crimps on aluminum radiator
find a local radiator shop to replace top seal and top plastic part
of that radiator
not as expensive as a new radiator
replace the thermostat
pressure is too much on that crack for any diy repair product
pop off hose at the wrong time =cook the motor
Apr 29, 2017 | 1996 Isuzu Trooper
Expanding hose cracked near top plastic juntion where alum pole slides in. Need to know if it's possible to remove hose from plastic, shorten slightly to replace split section and reinstall hose to...
I don't know if it's possible to remove. But, something I often use for cracked plastic is a plastic weld.
Just take a soddering iron and a cheap peice of plastic (I often use the clear constainers salad comes in) and melt it into the hole. It's an easy inexpensive way to fix things.
Dec 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The plastic part of the top of the raditor has crack do i need to replace the whole radiator or can the plastic be replaced ?
buy a fiberglass repair kit and patch the crack. The kit will come with cloth,resin.stick and sandpaper. Sand area,cut cloth,mix resin,use stick and apply to cloth. Hope this helps Tim
Aug 28, 2010 | 2001 Suzuki Grand Vitara
A crack along the top of the radiator. can that piece be replaced or do I need to get a new radiator?
They do make replacement plastic radiator tank's, but only for the side's, not the top, will have to replace radiator.
Jul 20, 2010 | 2002 Kia Optima
My 1998 Chevy Silverado has coolant leaking from the radiator at the small metal fitting at the top drivers side of the rad. Is the a seal that can be replaced or does the entire rad need to be replaced?
There's not usually a seal for these, the metal is commonly molded into the plastic sides of the radiator.. Remove the radiator tube and inspect the plastic around the fitting for cracks. If you find cracks in the plastic, then you know your answer. If it's leaking from around the radiator hose you could try replacing the clamp with a hose clamp that you can tighten with a screw driver.
My guess is the plastic is cracked there, and the radiator needs replaced, but you should inspect it first of course.
Good luck
May 09, 2010 | 1998 Chevrolet C1500
The top case surround the screen has cracked on both sides of the latch and cracked on one corner. No rough treatment.
So what are you asking?
Sounds like you need to replace the top of the case. I have no idea why it cracked--you said there was no rough treatment (by you?)
Could someone else have messed with it?
It could possibly be a factory defect. If your machine is under warranty, that would qualify for replacement of the plastic. Otherwise, you're going to have to either glue it or buy a replacement bezel.
Jul 08, 2009 | Panasonic Toughbook 52 - Core 2 Duo P8600...
Salton Yogurt Maker GM5 plastic lid replacement
I have the same problem.  I used to place plastic wrap on top and still use the old cracked lids.  Now, I cannot find my instruction booklet.  Can you help me?
Jan 01, 2009 | Crock Pots & Slow Cookers
Hearthware Home Products Nuwave Pro Infrared Oven Logo
Top Hearthware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Hearthware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
