Need direction of how to download anonymox
How do i download the Anonymox to enable open a a site that needs an ip
  • 295 Answers
First, you'll need the Firefox browser (in case you haven't got it yet). http://www.firefox.com
Then start Firefox and surf to: https://www.anonymox.net/en/download
to download and install Anonymox.
Posted on Jun 28, 2014
I cant activate my code for premium anonymox
Did you pay for the premium service?
As this generally happens when you try to use the pirate hack to get it for free.
Apr 09, 2014 | Mozilla Firefox
Unblock flipkart site
Certain websites are open for only people from certain region of the world. It would have been blocked to people from other region based on their IP address range. In such case, you can access the specific site using an IP hider software like smart hide IP or use any VPN service. Once you have enabled an IP hider software, you can visit IP-Details.com and have an IP lookup to ensure the change in your IP address.
Feb 26, 2014 | flipkart.com
Is the Belkin N Wireless Router (F5D8236-4) compatible with Windows 7?
Yes it is compatible for all windows version after windows xp.
IF you want to configure it follow below direction.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 08, 2010 | Belkin F5D8236-4 Router
I need to download the setup software for a Linksys WRT54G and cant find it online.
There's no need to download any software.
Use an Ethernet cable to connect your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD and press ENTER.
Type IPCONFIG and press ENTER.
Look for a line of output like:
Default Gateway . . . . . . . . . : 14.64.1.1
Start Internet Explorer.
Type http://14.64.1.1
to connect to the web-server "inside" the router.
Click to run the "network setup wizard"
Later, click to run the "wireless network wizard".
Disconnect the Ethernet cable, and have your computer "view available wireless networks" -- you should now be able to "connect" wirelessly to your router.
Nov 19, 2009 | Linksys Wireless-G WRT54G Router
How do you change nat settings when it only lets you enable it?
Without knowing your exact model of router, I can not give you specific directions. But I can tell you what you need to do in general.
First of all check your ethernet cables to make sure they are firmly in place. Ethernet cables with the retention clip broken off have a tendency to not fully seat.
Next you need to get into the configuration of your router. This is done via a web browser interface. You will have to navigate to an address of something close to http://192.168.1.1 or http://192.168.0.1. It depends on your specific router brand.
Once inside your configuration, you want to look for the internal IP your 360 uses. It will be something like 192.168.100.3. You can also grab this IP address from your 360 in its network settings menus.
Now that you have the IP of your 360, you want to forward the following ports to that IP address: 88 UDP, 3074 UDP and 3074 TCP. Save the setting changes and test your NAT status again. If all is well, then you are done, if that didn't do the trick then continue reading.
Next you can enable DMZ for the IP of your 360. Make sure you do not accidently put in the IP of one of your computers. Save the settings and test your NAT status again.
If it is still not working, look for an option called "UPnP", turn it on.
One of the above should have given you an "open" NAT and solved your problem.
If you want to read more on this, here is a link to Microsofts explaination of the issue.
http://support.microsoft.com/kb/908880
Sep 14, 2009 | Microsoft Xbox 360 Console
My laptop cannot automatically pick up an IP address
Don't send it away.
To automatically get an IP addressed assign you must have the network adapter set to "Obtain an IP address automatically"
Check it from a command prompt
click on start | run| type in cmd to open a command window
type ipconfig /all in the command window and see if Autoconfiguration Enabled . . . . : Yes is in the list of information, if not follow the guide below to change it.
DNS service and DHCP service are not normally run on a person's computer, these are services that run on remote internet servers, local network servers or router/wireless access points, to name a few examples.
You need to verify that your network adapter's TCP/IP settings are set to automatically obtain an IP address.
Go to network connections and open the window.
Find your network adapter and right click once on it and select "PROPERTIES" at the bottom of the context menu list that appears.
Usually this will be labeled something like Local Area Connection.
Right click on it and select properties.
In the window that open you'll see several items with checkboxes, find the one labeled
Internet Protocol (TCP/IP), click once on it to select it and then click on the button "PROPERTIES"
Look and see if the bullet choice "obtain an IP address automatically is bulleted, if not click in the circle to enable the bullet.
While in that properties sheet, make sure that the item Obtain DNS server address automatically is also bulleted (selected)
Click OK, OK
click on START | RUN and type in the box cmd to open a command window
in the black command window type the command
ipconfig /all
you should see an IP address, subnet mask and default gateway along with lots of other IP info
see if you've got an IP address in the list. If not type the following in the command window
ipconfig /release
this will force the IP to release any address it is holding
then type
ipconfig /renew
this will force a renew of the address
C:\Documents and Settings\tolm4454>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : NAME OF COMPUTER
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . :
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Cont
roller
Physical Address. . . . . . . . . : 00-19-B9-43-65-C3
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 10.53.0.148
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 10.53.0.254
DHCP Server . . . . . . . . . . . : 10.53.100.252
DNS Servers . . . . . . . . . . . : 10.53.100.195
10.53.100.136
10.23.100.22
Primary WINS Server . . . . . . . : 10.53.100.253
Secondary WINS Server . . . . . . : 10.53.100.252
Lease Obtained. . . . . . . . . . : Monday, March 16, 2009 12:22:20 PM
Lease Expires . . . . . . . . . . : Thursday, March 19, 2009 12:22:20 PM
Mar 16, 2009 | HP Computers & Internet
I cant istall dlink dwl 2100 acess point.prescribed site is not opening
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
Jan 24, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Can't access one computer from remotely.
enable portforwarding on your router and type in any name for your ndvr and the port number that you need to use for your ndvr to access it and the IP address of your ndvr(local IP)
where to check the port? ask you ndvr vendor for the port range that need to open on your router
local IP? assign IP local IP to your ndvr make sure you assign static IP for it.
make sure your enable port triggering and type in the port range for your ndvr.
im happy to hear more from you
Nov 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Need to change server address???
hey , ya have 2 solutions first ya assign static i to all comps with the range 192.168.1.2 n 3n 4 like on. OR second solution is : ya log oninto the router with hard wired connection thru ethrnet cable, open browser , type the ip of the router , go into it , then select "LAN OR IP SETTINGS" it will show ya the routers ip as 192.168.1.1 chnage it to 192.168.11.1 n start ip add will be 192.168.11.2 last/end ip will be 192.168.11.254 n save the settings. if both things dont work then you need to upgrade the firmware which ya can download from the respective site of product manufacturer. before ya go for firmwware ya need to confirmed of this issue , or talk to me with the results.--- take care - samrat
Mar 15, 2007 | MSI Wireless-G RG54G3 Router
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
