Question about Supersonic IKONVERT Digital TV Converter Box
Simply stopped working
Will not turn on
Why has right button on mouse stopped working?
Yous search was absolutely correct. If right button stopped working, or let's generalize, if a mouse stopped working correctly, there is no practical way to fix it unless you have some very good technical knowledge. simply, it's not worth to repair them. Might cost more then the value of a new mouse.
Mouse are consumible and disposable. If one stops working, you simply should replace it with a new one and "recirculate" the old.
Oct 04, 2015 | Computers & Internet
Suddenly stopped working, not charging.
it is possible that the bluetooth connection being cut midcall to have froze the bluetooth headsed, one thing you should try is to power it up in connection mode and see if it works, there are different combinations of buttons, assuming you have power and volume buttons to do a hard reset to it... otherwise i think you should take it where you bought it and ask for solution even if warranty period is over because it simply isn't normal what happened.
best of wishes and hope i helped. good luck
Mar 10, 2014 | Motorola Mobility HK202 Bluetooth Headset
Have a whirlpool dryer, le9380xtwo and it simply stopped working
Remove the rear panel on the dryer and on the lower left you will see the thermal fuse that needs to be replaced. Here is the part to order.
Nov 19, 2012 | Dryers
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a safe with combination lock. I know the combination. however, I don't recall the simply rotations. like our old combination lock on a locker at school was: spin to the right or clockwise to clear...
hi, it should be turn right then stop on 1st number then turn left stop on 2nd number then turn right stop on 3rd number then turn left stop on 4th.
This should then solve your problem.
Let me know how you get on or if you need further assistance ok
Jan 20, 2010 | Schylling Combination Steel Safe
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Stopped working
I had a simular probleme with my older model filter queen vac and it turned out to be worn brushes on the motor I simply ordered new ones installed them and then and all it costs was 15.00 usd to canada probably less in U.S. go to this site you'll find all you need there. www.lighthouseenterprises.us
Aug 29, 2008 | Filter Queen Majestic Canister Vacuum
Supersonic IKONVERT Digital TV Converter Box Logo
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
