Question about Whirlpool GH4155XP Microwave Oven
Humming noise from control panel
When pluged in control panel hums
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
This usually means that a micro switch is faulty, check the micro switch and replace if faulty, there should be two micro switches
Posted on May 17, 2014
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
Oct 28, 2016 | In Microwave Ovens
Ge spacemaker II microwave started humming and nothing showing on monitor
My parents have had a couple of the spacemaker microwaves mounted over the range with the built-in vent. Over time, the seal on the control board gets a crack in it and the steam from cooking below it gets up into the control board and does it in.
Even if yours isn't mounted over the range, it sounds like a main control board failure.
Sep 10, 2016 | GE PEM31DMBB Black Profile Spacemaker II...
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
When the microwave is plugged in but not running there is a buzzing/humming noise.The unit works fine and the buzzing/humming continues when in operation as well.
That noise you hear is loose laminations in the standby/controll transformer. It is no more than a nuisance.
The transformer can be replaced by contacting the manufacturer and browsing for a dealer near you.
Hope that helps.
Dec 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Jan 20, 2010 | GE JVM2070 Microwave Oven
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Jul 16, 2009 | Microwave Ovens
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
Humming sound
In my professional opinion, it sounds like you have a shorted relay or other defective component on your control circuit board, which is actually made by Samsung. We regularly repair these control panel assemblies nationwide for $32.50, so the problem can certainly be fixed economically. Looking at typical microwave wiring shows it has to be the cooking relay or a device that drives that relay. Since it stops when you open the door, we can say the door switches are certainly doing their job.
Oct 26, 2006 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
46 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
