Question about Hobart Airforce 250ci Plasma Cutter 12 Amps
Hobart air force 250ci 115Invertet-base plasma cutter with build compressor the amber light remain on
The yellow light re-main on, Even when I shut off the Machine and turn it back it go back to the yellow. how do I fix this problem?
2 Suggested Answers
SOURCE: need schematic for hobart airforce 250ci plasma
Found out the model was still under warranty.
Posted on Jan 29, 2010
Why dont i have any power to my hobart plazma cutter
Maybe blew a fuse . maybe malfuncttion. i would contact company for proper assistance.
Customer Service Hobart Welders
Mar 03, 2016 | Hobart Airforce 250ci Light Weight Plasma...
Will not arc
Sounds like the voltage is not going to the tip. I would suggest taking this in for repair.
Dec 07, 2013 | Hobart Airforce 250ci Plasma Cutter 12...
Machine turns on, air compressor runs but will not strike an arc
sounds like the voltage is not getting to the tip. I would suggest taking this in for repair.
Only cuts for 3 seconds, device still on
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Apr 03, 2010 | Hobart Airforce 250ci Light Weight Plasma...
Was cutting with it and it just kicked off like a breaker tripped, no power at all.
check the cable going into it,then the nozle i think the unit has a breaker type switch ? push it all the way down then back up again
Jan 07, 2010 | Hobart Airforce 250ci Light Weight Plasma...
Hobart 250 has power to unit, but will not run.none of the lights come on.
Sounds like you have more than one problem. Check all fuses. Bringing it to a welder repair shop might be a good idea. Welding suppy houses may be able to help you in your area, and maybe recommend someone.
May 01, 2009 | Hobart Airforce 250ci Light Weight Plasma...
Hobart 250ci quit working
Provided Air is between 60 and 80 psi (common operating range).
Power is measured to be in range as per label or manual specs.
Replaced all consummables on the torch head.
Usually the next step is to change the Torch Head. After all else fails this is usually the problem, especially if the torch head became hot while cutting.
Apr 10, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Hobart Airforce 250ci Plasma Cutter 12 Amps Logo
109 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
