Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
I have entered it below
I did go to all programmes and click to open it but it did not open. how will reinstalling fix the problem?
  • HP Master
  • 27,725 Answers
You might have to uninstall the current version you have on your computer then restart your computer.
Run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Then reinstall.
Posted on Mar 25, 2014
Frozen screen /application
Have you tried system restore and going back to a date where the software was not updated?
If that doesn't work, you might have to reinstall PS.
Nov 06, 2013 | Adobe Photoshop Limited Edition 5.0 for...
My webcam not work properly
Is this a Web cam that is integrated in your laptop?
If you are using a Windows XP or Newer, I would suggest going to Start>Control Panel>System and Securites> Under System> Device Manager Click on images Devices and right click on the sub menu below images Devices and uninstall the webcam. After doing this, Restart the computer and the the driver file should reinstall you webcam.
Jun 16, 2013 | Toshiba Computers & Internet
Windows 7 premium 7 32bit wont recognise andstart the disk to load programme
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Oct 20, 2011 | LG SecurDisc 20x External Double-Layer DVD...
My dvd rom not showing in nero programme
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 24, 2011 | LG GDR-8164B 16x DVD-ROM Drive -...
When i turn on my hp pavilion a1220 n . in about 45sec's a pop up comes up and reads EZ Dock int easy uistring config xml failed . what is it and how do i fix it please?
if you have xp computer follow this step: start/run/msconfig and hit enter. system configuration window will open then click on startup/disable all/apply/ok
restart te computer and issue will be fixed//
if you have vista computer- start/start search/type msconfig and hit enter.
if you have windows 7 computer- start/search programme and files type msconfig and hit enter.
May 12, 2011 | Computers & Internet
Acer Aspire Orbicam ...
Try the below steps:
  1. Press ‘Alt + F10' to start eRecovery Management.
  2. Enter the Acer eRecovery Management password, the default password is six zero's, or 000000.
  3. Select ‘Recovery Actions' and click ‘Next'
  4. Select ‘Reinstall Applications/drivers' and click ‘Next'
  5. On the left hand side of the newly opened window select Windows XP
  6. Select Driver
  7. Select Camera
  8. On the right side of the same window, click ‘Install Camera Driver Now'
  9. The unit will reboot after the installation is complete.
Mar 15, 2010 | Acer Aspire 5100 Notebook
My X3650 wont print anything apparantly due to a job stuck in system,on advice tried to uninstall and reinstall programme but wont let me!
hello
In this case do one thing
click on start- run - type services.msc hit enter
look for print spooler then do right click and restart the service or look for jas auditor and jas monitor for both the jas service stop and disable it
thgis will fix the issue
Thanks
Mar 10, 2010 | Office Equipment & Supplies
Orkut is opening with my account on several other pcs bt when it comes to home pc this sit is not opening ,i jst enter the usernsme and password bt the sites homepage never comes can u guide what the exact...
you have either blocked it by Norfton or another program or insecurity settings internet explorer. Download Firefox if you haven't already and see if it opens there.
To unblock in North, Run Norton Internet Security. Open up the main page of the programme and you will see Status & Settings on the LH side. On the RH side you will see System Status which should say O.K. click on Personal Firewall and you will see a box which says 'Turn Off' and below that 'Configure' Click on this and let the Firewall search your computer for all your Internet programmes. The job is done for you, and if any programmes pop up that you don't want you have the opetion to uncheck and remove. If the problem is in IE itself go to Tools, Internet Options, Security and check to make sure that the program you want to allow access is in the Trusted Sites and not in the Restricted Sites. This should fix your problem.
Dec 28, 2009 | Microsoft Windows XP Professional With...
Cant reinstall printer to my computer
You can download the software you need from:
Lexmark Support
Enter your model in the search block.
Next page, click on "Download Driver".
Next page, enter your operating system.
Next page click on "Download Now".
When the download window opens, choose "Save" and save it to your computer where you will know how to access it after the download.
Follow the setup guide. (Here is a link if you do not have it: X1100 Setup Guide )
When you get to the software install, you need to go to the file you downloaded and run (double-click) it.
You can always burn a CD of the file for future use if you choose.
Jan 12, 2009 | Lexmark Office Equipment & Supplies
Print Workshop 2008
Describe Your Problem:Please describe the problem to get it solved
I bought this print workshop 2007 since around November 2006. It work wonderful until January or February of this year. I rely deeply on this programme in which i used every week until this message below stop me.
I did reinstall this programme.Still will not work.
Same message.I did click the continue button but the programme will freeze.I will go crazy if this does not work for i need the programme for work.
The message is below.
An unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quit, the application will be shut down immediately.
Exception has been thrown by the target of an invocation.
Aug 14, 2008 | ValuSoft Print Workshop 2003 for PC
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
