H pavilion dv5 2134ca touch pad
The light on my upper left touch pad is now red, and with this it seems to be frozen or turned off. I read a suggestion to double click that area which did not work. I also tried to find the button "under the amber flower" but my computer does not appear to have this. what can I do?
  • 4 Answers
The button you are looking for should actually be right on your touchpad. It's in the center at the top of the pad. Just press it and your light should go blue
Posted on Mar 25, 2014
frenzy19
  • 258 Answers
SOURCE: touch pad
your touch pad might be disabled find the fn key + touchpad icon usually found between F1 to F10 the icon is like a square with pointer above it
Posted on Nov 20, 2008
Fixe_You
  • 1800 Answers
SOURCE: left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Posted on Dec 30, 2008
SOURCE: How to repair the left click button on HP Pavilion ZT1135
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Posted on Sep 25, 2009
SOURCE: UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
you can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Posted on Aug 23, 2010
SOURCE: I have a Compaq presario
Just double tap the same area ie the light that came on when you did it the first time.
Posted on Nov 01, 2010
My ph pavilion dv7 touch pad's light is off, what must I do to get it on again?
Looking at a picture of the laptop, it is like most HP computers. There is a button directly above the touch pad. This is your on/off button. Press it and wait a few seconds, and the light should turn blue.
Mar 16, 2012 | HP Pavilion dv7-1137us Notebook
What is the tiny orange light about in the left corner of my HP pavilion key pad ?
"You can double-tap a dot in the top left corner of the touch pad to disable it; a small orange light will appear to indicate that it's turned off."
Mar 01, 2011 | HP Pavilion N5495 Notebook
A red light comes on my hp touchpad and I loose all control, and can't get it back. How do i re-gain controll of my touch pad?
It shows that you have accidentally shut off the touch pad. In the upper left corner of the touch pad is a dimple/circular depression. Tap it twice, the light will go out and normal touch pad function will return.
Oct 10, 2010 | HP P2360AA Keyboard/Mouse
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Oct 30, 2009 | HP 2133 Mini-Note Notebook
My touch pad seems frozen, yet all else works fine, what do have to do to get enabled again?
There is a button on the laptop that disables the touchpad. Press it. Or it might be Fn + one of the function keys.
Aug 14, 2009 | HP Pavilion dv1000 Notebook
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Screen frozen, touch pad not working
there is a switch nearby that orange light or the light may be a switch. press on it then the color of light will change and ur problem will be solve....thats all
Dec 21, 2007 | HP Pavillion ZV6000 Notebook
Computer Frozen, Touch pad not working
Computers & Internet Logo
David Payne
David Payne
