Question about Garden
Auger bad Can't get the belt wheel off
    Guru:
  • 145 Answers
Snow thrower?? pulley between wheels and sheer bolts??
Posted on Apr 12, 2014
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
Dec 03, 2016 | Garden
Auger belt on snowblower keeps breaking after about an hour of use, please help.
Try removing the drive belt and turning the auger by hand . If there is no problem it will turn freely by hand but if it feels tight check the auger tube for bends or dents that will restrict the free movement of the shaft. The next thing to check is the pulleys If they are "V" belts then check that you have the correct belt or the correct pulleys for the belt. A "V" belt is fitted correctly when the top most width of the belt is about 1/16 " above the rim of the pulleys . IN other words it just sticks out of the pulley. The pulley sides have to be smooth and not stepped as this creates different running speeds for different sections of the belt and that generates heat. Imagine a duel tyre wheel where one tyre is 2" larger than the other but both are running on the road . As there are different circumferences there fore different distances covered in one revolution Then one tyre is being dragged along. The same applies if the pulleys have steps in the sides from wear.. If it turns freely but feels lumpy then you will need to replace the bearings . Check inside the auger tube as there may be some thing like rope /cloth or wire jammed and acting like a brake.
Feb 05, 2014 | Cars & Trucks
Honda hs55 when handle depressed blower fan moves at fast speedauger turns very slow.if auger makes contact with snow auger and blower fan stopsnew belt was installed no slippage of belt present
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
Dec 05, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Replacing both Drive belts on toro 832 snowthrower
If you tie both the auger and the drive handles down that will give you enough room to get the belts out, and when you put the new belts on be sure to get the belts inside the belt guides otherwise you'll be replacing them again.
Jan 10, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
