Question about Bobcat Equipment Skid Steer Flatbed Tractor Trailer
I've got an error code 16-06 on my Bobcat T140 Skidsteer
Manual says traction control short to ground.
2 Suggested Answers
  • 3828 Answers
SOURCE: I need a s650 bobcat skidsteer loader repair manual
can chase a paper book version or
Free download KOMATSU manuals
$6.50 downloadable link works
http://seadoomwewtu.blogspot.com.au/2013/10/free-instant-downlod-bobcat-s650-skid.html
Posted on Apr 29, 2016
What needs to be done for error code C1201
Hi on the code that I have for that,it says.
ABS inlet coil LF circuit short to ground.
Hope this was some help,all the best.
Sep 02, 2016 | 2006 Lexus Is 250
My 873 Bobcat aux hydraulics turn the wrong way it was working fine but now turns only clock ways, what is wrong
this model has got something called bi directional valves on the remotes , meaning it can move both ways , now there can b three reasons for this to go only one way , first the simplest is , what is called a lock-out reverse setting , this forces the remotes to move only one way , (there should be a note in manual about this) the second reason is the directional control valve is defective , and last but not least if your ffeedding a hyd motor with this , the motor could be defective and its only moving one way and not with much force either (a simple sub out of an std cylinder would show this)
Aug 24, 2016 | Bobcat Garden
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
Feb 20, 2015 | Bobcat Garden
Is there an easy way to change the alternator on my 2000 751 bobcat skidsteer? I am having a hard time accessing it and I need to replace the alternator bracket.
about the easyest way is to have very long arms or you'll have to remove the radiator just like the rest of us short'tys
Jan 01, 2015 | Bobcat Garden
How do I change the alternator on a Bobcat 773 skidsteer loader
Why do you suspect the alternator? Have you checked the output? Put a meter across the battery terminals when running at fast idle and it should be 14.5volts and no less than 13. Poor cold start is usually the heater plugs/ failed heater plug timer or poor battery strength. Start at the beginning and see if the alternator is working OK, then work through the rest. Test the heater plug supply by putting the meter from the plug supply cable to ground when the switch is in cold start position. Should have 12v at least. Make sure both battery cables have good clean connections at both ends to chassis or starter. Most cold start problems can be fixed by careful maintenance and basic systems checks.
Nov 15, 2014 | Bobcat 773
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
BobCat 763 service code 17-06 valve output shorted to ground
bobcat 763 valve output circuit shorted ground
Jun 24, 2012 | Cars & Trucks
Bobcat 753 skidsteer right drive control is jerky going forward and trying to turn,it dosent want to feather in.Thanks Pete V.
check and, clean the hydrolic directional combination valve screens; dirt in the lines causes this
Sep 14, 2009 | Garden
Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Jul 19, 2009 | Bruder Cat Skid Steer Loader
Bobcat Equipment  Skid Steer Flatbed Tractor Trailer Logo
80 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
