Question about Tools & Hardware - Others
Ariens snowblower manuals
How do change one of the augers
  • 3,368 Answers
That depends on which model you have. Post with more information, that will help somebody solve your problem.
Posted on Jul 01, 2014
Start my new snowblower auger keeps turning
Belt is a bit too tight. If it's NEW it will probably stretch a bit and be OK
Dec 23, 2014 | Ariens 72023 Snowblower Drive Belt 1/4 X...
Right side of snowblower is constantly clogged with snow
Check the R.H. auger my guess is you have a shear pin that has broken and needs to be punched out and replaced. If it rotates freely (cleaned out of snow) then that's likely your problem. You can prove that by watching the shaft the auger is riding on if the shaft moves with the auger shear pins ok. If the auger moves seperate from the shaft the shear pin is at fault.
Feb 21, 2013 | Ariens Garden
How to change drive belt-Ariens 522 snowblower-model # 938017
Which belt? You are referring to the auger drive right? The self propell uses a friction disc drive.
The auger drive has two belts, and in order to replace them you need to seperate the auger from the engine (split) the blower.
Happy days.
Matt
Dec 13, 2010 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Tools & Hardware - Others Logo
52 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
