Question about Black & Decker Toaster Ovens
Unit does not work there appears to be power but the digital display only displays dashes on the screen and no buttons function
The unbit is clean and there appears to be power to it (there are three dashes on the digital display when we plug the unit into power)
Digital display breaking up
it happens commonly with LCD we can do nothing replace the display unit
Jun 10, 2015 | Breville The Smart Oven Convection Toaster...
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
Bravetti euro pro microwave convection oven stops working
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2hPnOVle4
Oct 11, 2013 | Toaster Ovens
Unit will not turn on. No power to anything on the display. The outlet is verified working. This happened once before and a few hours later just miracled itself back to life. any idea Is there some...
An loose, intermittent power switch is the cause of that and it associated with lose wiring inside. Check it and replace lousy parts once you done that your unit will back to normal again.
I hope my idea help you.
Apr 04, 2011 | Cuisinart TOB-155 1500 Watts Toaster Oven
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
On off button usually fais to respond to on
It could be a problem with the board as that on/off button is one complete unit with the board, digital display and buttons attached. If you want to fix it yourself get your model number (FBC212) and head over to 1800Parts.com to see if they have the board in stock. You can also call Krups directly and they will tell you a service station in your area. We are one of their national service stations but we are in New York.
Sep 15, 2010 | Krups FBC212 1600 Watts Toaster Oven with...
Setting clock on krups toaster oven
buttons.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Does not heat up.
Mine worked for awhile, then started overheating. I (former appliance repairman) found that the fan needed oiled. While I was checking it with the outside covers removed, I saw that two of the connections on the top heating element were arcing and burning! This accounted for a strange smell.
Jul 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Toaster Ovens Logo
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
