Question about Newco CBD-1.5 Dual Commercial Barista Coffee Brewer
Need to brew coffee
I can not brew any coffee I have a list of error codes and need to find a list so I can fix the problem
  • 1,511 Answers
You need to go on line to the manufactres web site and seek Support.
Posted on Mar 25, 2014
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
What is error code 73?
F73 is a Brew unit fault - its possible it may only need cleaning - but more times than not there is a mechanical issue with the unit running through its cycle. There are a series of switches to monitor the brew units movements so the system knows where the is, or in this case is not - the brew unit is not moving properly to the position desired
Jul 05, 2014 | Miele Cm 5000
SUP 0320R - ERROR CODES
we are getting a rapid flashing between the prime and coffee icons, flashing back and forth, when we push the brew button.
the machine does not need descaling, it primes properly when turned
on, it is only when I try to brew that it begins this rapid red flashing between the two icons.
Aug 08, 2013 | Saeco Coffee Makers & Espresso Machines
No coffee!!
You might need to set the clock try that
May 01, 2013 | Coffee Makers & Espresso Machines
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Making Coffee
Ok lift the lid and inside you will see a brew basket (it will have a hole in the bottem middle of it) If this unit has a mesh type filter basket you will not need paper filters! you put the coffee in the mesh basket the replace before brewing! if you do not have a mesh basket you will need a paper filter to put down in the coffee holder!(the one with the hole in the bottom!) add coffee and waeter and brew!
I hope this fixes ya up!
Please rate my response!
THANK YOU!
Jan 16, 2009 | Kenmore DCC-KE12 Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
Newco CBD-1.5 Dual Commercial Barista Coffee Brewer Logo
47 people viewed this question
Top Newco Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
