Question about Philips Televison & Video
Philips DVP3560 plays DVDs with no sound and the picture squashed over on the left-hand side of the screen for the first several minutes of running before picture and sound resolves on its own.
I've got a Philips DVP3560 upconverting DVD player. We've had it for over a year, and just recently it's begun to have an odd problem. When it first begins to play a DVD it will play the DVD with no sound and with the picture squished over on the left-hand side of the screen. I haven't timed how long it does this, but the problem does resolve itself after about 5 minutes, sound comes back and the picture displays normally (across the entire screen). I've checked the HDMI connection, and everything seems to be fine there. Any thoughts as to what is causing this weird problem, and how to get it to not happen (short of buying a new DVD player)?
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
SOURCE: black rectangle at bottom of screen when playing dvds on sony dvd player
Had the same problem but was able to fix it by simply doing the following:
"this is closed captions turned on your TV. get your original TV remote and look for a button that says "Captions" or "CC", and keep pressing it until the TV says "Off". if it doen't have one of those buttons, you will need to get into the menu of the TV and turn off closed captions there. It is probably set on "Text1 or Text 2" right now, and it needs to be set on "Off"
Posted on Dec 20, 2008
SOURCE: No sound
Just throw the freeking thing in the garbage. I purchased mine a month before they shot down HD DVD. I purchased a ton of HD movies on Ebay since I paid for the player. No audio....Same issues. I am an electronics technician by trade. I don't know the computer side though. This is a hardware issue and this thing is a piece of ****. I have tried analog outputs, hdmi, optic, and none work. Shame on Toshiba. They knew when they started selling these pieces of **** that Bluray was going to be the format of choice and thats why they wer only $400.....The worst money I ever spent. Now I have a bunch of HDDVD's that I can't play. Double fucked. I would love the thing if I was deaf. Great pic. ******** toshiba!
Posted on Dec 12, 2009
SOURCE: Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Posted on Jan 26, 2010
After one DVD movie was run several dozen times, the player would no longer
If you are talking about it won't play, the laser pickup is the issue, have you tried other dics? if no change! buy a DVD cleaning kit and follow instructions, this will clean the laser lens and perhaps get it running.
Mar 17, 2012 | Philips DVP3560 DVD Player
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
There's a green bar when I play movies
Make sure wires from DVD player are not close to the side of your TV. The radiation from the TV can induce interference on the wires causing bars or static on the screen.
Feb 06, 2011 | Philips DVP3560 DVD Player
I Need to remove region block from the DVP3560 as I have DVDs from several regions.
1. No DVD in the tray. The tray closed. The unit and TV on.
2. Press "Setup" on the remote.
3. Press the "down" arrow repeatedly until the top heading shows "Preferences."
4a. Then press "OK" and Audio will be highlighted.
b. Press the "down" arrow and the next category "Subtitles" will be highlighted.
c. THEN enter this 6-digit code: "138931"
Immediately the screen will show "Region Code 1".
d. Press the "up" arrow and "Code 1" becomes "Code 0". All Region or Region Free.
e. Press "Setup" to exit.
5. Turn off and then back on to remove green bar along the top of the screen
just did it. worked perfectly!!
Feb 01, 2011 | Philips DVP3560 DVD Player
My new Philips DVP3560K DVD player is getting hanged after 15 minutes play of DVD CD. What should I do?
Try going on Phillips.com/support to get a firmware update if it has a ussb slot to do so other then that if it's new take it back.
Jan 27, 2011 | Philips DVP3560 DVD Player
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
