Question about Stanley TR250 H Heavy Duty Heavy Duty Staple/Nail Gun w/ Free Staples
Help need to no how to load the brad nails
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how do I load nails in Stanley powershot staple/brad nails
you can try and go to Stanleytools.com and get to their knowledge base of FAQ or they have a direct way to contact the company for the information you need. I was on their site and have seen better to help the end user.
Posted on Dec 30, 2008
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
SOURCE: how do i get a
there should be two top allen screws that loosen up magazine. after you do this take a flat screwdriver and bang back driver. olny bang driver back if you need to.
Posted on Aug 05, 2011
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
My nt50ae2 brad nailer jams in the magazine. the feeder rides on top of the nails.
This happens. The follower jumps over the nails and the magazine binds.
Step 1. Remove nails, unplug hose.
Step 2. Remove the bolt at the bottom of the magazine with a 2.5mm hex key.
Step 3. Remove the magazine while holding the nail follower in place to the magazine cover.
Step 4. Carefully remove the nail follower and gently extend the yellow warning indicator and follower spring.
Step 6. Inspect the nail follower. There should be 3 indentations that are stamped into nail follower face. This is the culprit.
Step 7. With a small punch, make these three indentations deeper.
Step 8. Assemble and test. Repeat if necessary.
Hope this helps.
Jul 28, 2012 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
How to load brads into stanley tre 550 electric staple/brad nail gun
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
How do you load nails in stanley tr250 staple and nail gun??
The magazine on the TR250 has a recess on one side as well as a relief at the top where the driver pushes them through the opening. Load the brads/nails on that side of the magazine and it should operate properly. AS A REMINDER: ALWAYS REMOVE NAILS/STAPLES/BRADS WHEN NOT IN USE AS THIS WILL WEAKEN THE SPRING AND CAUSE FEED PROBLEMS IN THE FUTURE.
Dec 22, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
Power shot nail gun? how do you load nails into it? i can do th
With the brad head torwards the top, just slide the brads down the center of the track, (same one as for staples), and then insert the follower. Hope this helps.
Jul 05, 2009 | Hand Tools
May 20, 2009 | Stanley Bostitch BT200K
Inserting brads into my Stanley TR250 Staple Gun
I bought one of these guns today and I had the same problem and it took me about 2 hours to figure it out as the instructions were very poor. Here how to load the brad nails:-
(a) Pull the slider bar all the way out
(b) Place the brad nail stick on the left side, IN FRONT OF the slider, NOT in the narrow gap in front of the two arrows where it says "LOAD BRADS"
(c) The nail heads should be facing the handle of the gun
(d) Close the slider and lock it
(e) Try it out. I tried nailing hardboard onto chipboard. The lever at low power only put the nail in about 30%. On Hi power it went in about 80%.
Good Luck
Peter
Jan 07, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
How to insert fasteners
Already posted in response to a similair question, however repeated here to close off open query!
Good Luck
Peter
How do I load nails in Stanley powershot staple/brad nails
Dec 22, 2008 | Stanley Tools Staple/Brad Nail Gun
Stanley TR250 H Heavy Duty Heavy Duty Staple/Nail Gun w/ Free Staples Logo
35 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
