Question about Jenn-Air Kitchen Ranges
Several buttons, such as the Bake and Broil, are suddenly not working. Other buttons such as the Convection and Timers work. Is there a way to reset the entire over? I tried turning off the breaker for a couple minutes.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
What is the model number?
Posted on Mar 25, 2014
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 521 Answers
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
huuum
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Posted on Oct 16, 2008
FixinFax
  • 3085 Answers
SOURCE: Range bake,broil,oven warm-up,oven light do not work
Yes the control panel is bad
Posted on Feb 24, 2010
SOURCE: Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Posted on Jun 11, 2010
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
I self-cleaned the convection oven on my sc302tw, and now it does not heat on any settings, convection, bake or broil. It is 14 years old.
Looks like the sensor has tripped... on my Bosch oven, I opened the back. Connected to the thermostat is a switch with a little button which pops out to prevent the oven from overheating... push in the button to reset it and it should work
Nov 06, 2013 | Thermador Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be...
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Mar 20, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Hello stevefer
Welcome.
First,
Huuum
Oct 16, 2008 | Kitchen Ranges
Kitchen Ranges Logo
88 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
