Question about Dell Vostro Computers & Internet
Vostro 1000 powers on for 5 seconds then shuts down
It will not stay on. i take the battery out and hold the power button down for 60 seconds and it will power on again for about 5 seconds and then shut down.
    Genius:
  • Dell Master
  • 1,274 Answers
I'd pull the ram out and see if it stays on w/one stick at a time, also make sure your fan is functioning, because that will also prevent it from staying on
Posted on Mar 24, 2014
knotbeerdan
  • 413 Answers
SOURCE: laptop doesn't work on battery after charging
If you are planning to open the notebook make sure the cpu cooler is mounted flush and has the most possible amount of contact with the cpu for heat transfer. I don't know about yours but normally in bios you can set a fatal temperature shutdown. Try to look up what cpu you have (when you open the case) and see if maybe the temperature is set too low. Then you would be able to reset the temperature to something higher if possible and this would solve the overheating shutdown problem.
Posted on Jan 02, 2009
SOURCE: My Dell Laptop will not power up! Dell inspiron 1000 notebook
take the cmos battery out and put in the power cable, and start the machine
Posted on Mar 26, 2009
  • 85 Answers
SOURCE: Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
Posted on May 09, 2009
SOURCE: acer aspire one model ZG5 does not boot
After a normal restart yesterday, my Aspire One booted into just a black screen. No POST, no BIOS, no hard drive light activity, just the power button LED on and the fan running fast. I was not very happy…
I went to the Acer Aspire One User Forum and started looking thru the Hardware section. I found this thread Dead aspire one and it looked like many others had a similar experience. After reading many stories of warranty repair or replacement, I was just about to dig up my receipts when I found this post: Re: Dead aspire one.
It seems that a lot of people had success reflashing the BIOS from a USB drive using tools provided by Acer. I don’t know if it’s officially supported by Acer or if it will void your warranty, but if the computer’s a paperweight now anyway, what the hell?
It’s very easy to do, but the steps are a bit unclear so here’s my attempt to make the whole thing painless. This worked for me, but it might not for you, so do this at your own risk.
You need:
A working USB thumbdrive you can erase. I used an old 64meg.
UNetbootin. Download from here: http://unetbootin.sourceforge.net/
The files to flash the BIOS. I used the most recent version from here: http://sites.google.com/site/maclesblogspotcom/
Download all the files to an easy to find location.
Steps to prepare the USB drive:
Format the USB drive using the FAT file system, not FAT32.
Start UNetbootin and choose FreeDOS as the distribution. Screenshot here.
Unzip the BIOS files and copy them to the USB drive
Make a copy of the BIOS file and rename it as ZG5IA32.FD (this appears to be very important - my reflash failed until I did the copy & rename)
Reflash the BIOS:
Make sure the AAO is turned off, the battery is attached and the power adaptor is plugged in.
Insert the USB drive
Press and hold FN + ESC and press the power button to turn it on. Release the Fn & ESC keys. The LED in the power button will flash.
Press the power button again once and wait. Mine took ~3 minutes, but I’d advise that you let it sit there for at least 5 minutes just in case your’s takes longer.
When the reflashing is done, the AAO will reboot and, hopefully, you’ll be back to normal.
If it doesn’t work, try reflashing again. The keypress sequence is a little tricky.
If the second try doesn’t work, then you’ll probably have to send it off for repair.
Good luck!!!
http://chromick.com/eric/aa1/aspire-one-black-screen-of-death/
Posted on May 13, 2009
  • 4 Answers
SOURCE: toshiba boots up power light stays on and shuts down, bad m/b ?
I own a Laptop Toshiba Satellite A75-S2131.
This series have a problem with the cooling flow to the processor.
The processor overheats and the laptop shuts down.To solve this particular problem you must tear down the laptop and clean up the processor heatsink (you will find it totally plugged or partially dirty).
Find in the internet the step by step instructions (with photos) for dismantling this laptop. Do not forget to apply thermal paste between processor & heatsink.
I hope this solution helps.
Posted by MCampos
Posted on May 31, 2009
The cap lock and scroll lock flashes and the number lock stays lit and it wont start on my Vostro 3500
This indicates a motherboard issue, remove main battery, and unplug the charger from the laptop, now press and hold power button for 60 seconds in hopes to reset the computer. Install battery and charger and turn on.
Jun 14, 2012 | Dell Vostro 3500 Laptop
When I went to shut it down it had a few programs to shut down. I waited a few minutes then closed the lid down. It is now flashing on the first light symbol on the corner and when you open it up it turns...
Sounds like it is stuck in hibernate mode. Hold the power button down for 5 seconds and try to start it again. If it doesn't start remove the battery, unplug the laptop, hold the power button down for 60 seconds. Now plug in the power supply but leave the battery out. Turn it on. It should start now and you can re-insert the battery.
Apr 22, 2011 | Compaq Presario CQ60-212US Notebook
When i boot my computer the screen stays blank and two lights flash on the under side of the keyboard what does this mean
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion dv7-1129wm Notebook
POWER IS ON SCREEN IS BLANK. WE USE TO SEE JUST THE ARROW BUT NOW NOTHING!
This can be due to the accumulated static charge is preventing the notebook to power up. Therefore, please run the steps to drain this power. I have included the steps to do so.
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer
May 26, 2010 | HP Mini 1000 Netbook
My hp dv 8000 Pavillion laptop will turn on and then it immediatly shuts down after 5 seconds or so
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
and if this doesn't help
then try to take out the ram or memory chip from the computer and place it back.
Jan 12, 2010 | HP Pavilion dv8000 Notebook
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
PC suddenly lost power will not restart
Dec 05, 2009 | HP Compaq nx9010
Hp tx 1000 black screen please hel
Nov 28, 2009 | HP Pavilion Tablet Notebook
My Hp mini is not turning on. The light next to the on switch is on but nothing happens on the screen, it stays black. Please assist
Nov 22, 2009 | HP Computers & Internet
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
