Question about Ford NOS 96 97 98 99 SHO Taurus 3.4L v8 Shortblock Assembly
Intake manifold torque specs
I need torque specs for intake manifolds on my 3.4l v8 taurus sho
SOURCE: I need the torque specs for the intake manifold
Intake manifold-to-cylinder head bolts for 5.0L V8:
Step 1 = 96 in-lbs Step 2 = 16  " Step 3 = 23 to 25  "
Numbers taken from an after market manual, so use at your own risk.
Posted on May 09, 2009
chuck943
  • 783 Answers
SOURCE: Ford 460 Intake Manifold Torque spec
22 to 35 ft lbs
Posted on May 22, 2009
  • 180 Answers
SOURCE: 04 f250 6.0 diesel need torque specs on intake
there are no torque specs! standard are 30 in pounds ! start from the inside out!
Posted on Apr 17, 2010
joeyandvic22
  • 18 Answers
SOURCE: torque specs intake manifold 97 f150 4.6
stage 1- 4 ft/lbs
stage 2- 8 ft/lbs
Posted on Nov 18, 2011
  • 183 Answers
SOURCE: torque setting for a 1998 ford taurus 3.0 intake manifold
TORQUE SPECIFICATIONSDescriptionNmLb-FtLb-InEngine Air Cleaner Tube Clamps1.6-2.2-14-19Engine Control Sensor Wiring Through Bolts2.5-3.5-23-30Generator to Bracket Bolt3727-Generator to Cylinder Head Bolt4835-Generator Brace to Upper Intake Manifold Bolts and Nut12-209-14-Intake Manifold Support to Throttle Body8-12-71-106Intake Manifold Support to RH Cylinder Head40-5530-40-Degas Tube to Upper Intake Manifold Bolts8-12-71-106Camshaft Sprocket to Camshaft Bolt50-7037-51-Camshaft Thrust Plate Bolt10-88Coil and Bracket to Cylinder Head Bolt40-5530-40-Connecting Rod Nut31-3923-28-Crankshaft Damper to Crankshaft Bolt125-16593-121-Crankshaft Pulley to Damper (4 Bolts)40-6030-44-Cylinder Head Retaining Bolt(1)(1)-Accelerator Cable Shield Bolts1.4-13Camshaft Position Sensor Housing Retaining Bolt2417-EGR Tube Connector to Exhaust Manifold40-4730-34-EGR Valve to Upper Intake Manifold Bolt20-3015-22-EGR Tube to EGR Valve and Exhaust Manifold35-6526-47-Exhaust Manifold Bolt/Stud20-2515-18-Flywheel to Crankshaft Bolt73-8754-64-Fuel Injection Supply Manifold to Intake Manifold8-12-71-106Throttle Cable Bracket1713-Dual Converter Y Pipe to Exhaust Manifolds34-4725-34-Crankshaft Position Sensor Bolts5-7-45-61Intake Manifold to Cylinder Head Bolt (5)(2)(2)-Main Bearing Cap Bolt75-8556-62-Oil Drain Plug11-169-11-Oil Filter Insert to Cylinder Block27-4020-29-Oil Filter to Oil Filter Adapter(3)(3)-Oil Galley and Cooling Jacket Plugs2014-Oil Level Indicator Tube to Exhaust Manifold Nut16-2012-14-Engine to Transaxle/Torque Converter Assembly Bolts40-6030-44-Torque Converter Nuts27-4620-33-Transmission Range Sensor Nut16-2212-16-Front Sub-Frame-to-Body Bolts77-10357-75-Oil Pressure Sensor16-2212-16-Oil Pump to Cylinder Block Bolt40-5530-40-Power Steering Bracket to Cylinder Head Bolt40-5530-40-Valve Cover to Cylinder Head Bolts/Studs (5)10-14-89-123Right Exhaust Manifold Heat Shield Retaining Bolts8-12-71-106Rocker Arm Seat to Cylinder Head Bolt(4)(4)-Water Outlet Connection to Intake Manifold Bolt10-14-89-123Upper Intake Manifold to Lower Intake Manifold Bolt/Stud20-3015-22-Engine Front Cover to Cylinder Block Bolt (No. 1-10)2518-Engine Front Cover to Cylinder Block Bolt (No. 11-15)10-88Water Pump Pulley to Hub (4 Bolts)20-3015-22-Water Pump to Front Cover Bolt8-12-71-106Wiring Retainer Bracket Nut20-3015-22-Valve Tappet Guide Plate to Cylinder Block10-14-89-123Ignition Coil Bracket40-5530-40-Oil Pan to Cylinder Block Bolt10-14-89-123Water Bypass Tube Nut20-3015-22-Crankshaft Pulley Bolts40-5530-40-
  1. Tighten in four steps (refer to illustration in Cylinder Head Installation for tightening sequence):
    • Tighten in sequence to 70-90 Nm (52-66 Lb-Ft)
    • Then back off all bolts 360 degrees
    • Tighten in sequence to 45-55 Nm (34-40 Lb-Ft)
    • Tighten in sequence to 85-99 Nm (63-73 Lb-Ft)
  2. Tighten in two steps
    • 20-30 Nm (15-22 Lb-Ft)
    • 26-32 Nm (20-23 Lb-Ft)
  3. Advance 3/4 to 1 turn after gasket contacts sealing surface or tighten to 13-15 Nm (10-11 Lb-Ft).
  4. Tighten in two steps:
    • 7-15 Nm (6-11 Lb-Ft)
    • 26-38 Nm (20-28 Lb-Ft)
  5. Refer to illustration in the Cylinder Head Installation procedure for tightening sequence.
Posted on Jan 10, 2012
F150 2013 V8 maifold intake torque specs
There is more than 1 v8, I need liter size of engine?
Aug 07, 2017 | Cars & Trucks
What are the torque specs and sequence for the intake and head gasket on a 1999 Chevy Silverado 6.0l V8 K2500
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
30 N?·m
22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence)
30 N?·m
22 lb ft
Intake Manifold Bolts (First Pass in Sequence)
5 N?·m
44 lb in
Intake Manifold Bolts (Final Pass in Sequence)
10 N?·m
89 lb in
Intake Manifold Wiring Harness Stud
10 N?·m
89 lb in
Oct 27, 2015 | Cars & Trucks
02 WIMDSTAR TORQUE SPECS INTAKE MANIFOLD AND SEQUENCE
always start in the middle, then work your way to the ends on alternating side bolts, bolts are probably 10mm or 3/8", if so around 18-24 ft/lbs torque maximum. don't use sealant on the intake manifold and the rocker cover should be 6mm or 1/4 bolts, same sequence just less torque, 10-12 in"/lb max
Jul 24, 2014 | 2002 Ford Windstar 3.8L Intake Manifold &...
What are the torque specs on a 2002 toyota sienna's spark plugs, air intake manifold, and valve covers? Thank you.
Spark plug torque on the 3.0L engine is 13 ft.lbs. and the 3.3L is 18 ft.lbs.
Valve covers-69 inch lbs.
Intake Manifold-11 ft. lbs.
Jul 07, 2014 | 2002 Toyota Sienna
I need torque specs for the intake manifold, heads and exhust manifolds on a 2000 ford tuarus
go to www. automecanico.com this web is in spanish however you can translate by your browser to english. is powerful
God bless you
Sep 18, 2012 | 2000 Ford Taurus
Need torque specs for a 2001 jeep cherokee intake manifold
Intake manifold using new gaskets. Torque the bolts, in sequence, to 105 inch lbs. (12 Nm)...
Fig. Intake manifold torque sequence-3.7 & 4.7L engines
Hope this help (remember comment and rated this).
May 07, 2010 | 2001 Jeep Cherokee
Need head bolt, intake manifold, and exhaust torque specs
Cylinder Head Bolt Step1- (25 FT.Lbs) Step2(45 Ft.Lbs) Step3(65Ft,Lbs).....Intake Manifold(35Ft Lbs)....Exhaust Manifold Center (20Ft Lbs) All Others (20 Ftlbs).....Thanks
Mar 06, 2010 | GMC Suburban Cars & Trucks
Need torque specs for for taurus
3.0L 2 valve 15-22 ft lbs
3.0L 4 valve 9 ft lbs
Jun 16, 2009 | 2001 Ford Mustang
Ford NOS 96 97 98 99 SHO Taurus 3.4L v8 Shortblock Assembly Logo
27 people viewed this question
Top Ford Tools & Hardware - Others Experts
john h
Are you a Ford Tool and Hardware - Other Expert? Answer questions, earn points and help others
