Question about Ford NOS 96 97 98 99 SHO Taurus 3.4L v8 Shortblock Assembly
98 ford taurus sho 3.4l v8 intake manifold torque sequence
I just need torque specs for the intake manifolds
5 Suggested Answers
chuck943
  • 783 Answers
SOURCE: Ford 460 Intake Manifold Torque spec
22 to 35 ft lbs
Posted on May 22, 2009
alicantecoli
  • 22219 Answers
SOURCE: I need the torque specs.
not listed in my alldata book sorry ,american ford not europeon
cast iron heads will be about 80lbs ,start in the middle and work you way out left then right and so on and it will be right ,pull first with a rachet then a nice bar and it will be right ,sorry but as i do it every day i never a use a torque wrench ,the inlet manifold bolts just pull up with a rachet but i would imagine around the 22/25 lbs as its a ally manifold ,throttle body ? just nip it up a little .Like the name and thats no doubt what your calling me but in all honesty i just pull them up with two passes ,first the rachet and then the snap on 80cm bar the last pull iam feeling for the stretch of the bolt is the only way i can describe it ,never had a gasket fail afterwards and never had to re torque the the head either ,Do they do this on the assembly line?' yes they do i know because i have got the job of torquing more than enough when i worked in fords on the assembly line ,Fine tolerances ?' so long as it fits with a bit of help from a 2lb club hammer and it will run for ever .Too be truthful i recomend a ford to anyone as other manufacturers are all the same as well
Posted on Dec 05, 2010
ercupa190
  • 12223 Answers
SOURCE: I need torque specs for the intake manifold, heads and exhust manifolds on a 2000 ford tuarus
go to www. automecanico.com this web is in spanish however you can translate by your browser to english. is powerful
God bless you
Posted on Sep 19, 2012
logan_rau
SOURCE: ford 4.2 intake manifold torque specs &
Torque specs for a 2003 f 150 4.2 L.
first pass 53 lb-in, second pass 89 lb-in
lower plenum
upper plenum
Posted on Oct 14, 2012
98 ford windstar intake manifold torque specs
Intake torque specs ' FordForumsOnline.com
www.fordforumsonline.com > Ford Tech Forums > Engine & Drivetrain
May 7, 2010 - 2 posts - ‎2 authors
ISO torque specs for the intake & plenum for a 98 Windstar...3.8 with the ... Our community is here to help you with any questions you have related to your Ford. ... Lower Intake Manifold to Cylinder Head Bolt 8-12 - (71-106).
Torque Specifications - AutoZone
www.autozone.com/.../Ford-Windstar.../Specifications/Torque-...
AutoZoneAutoZone Repair Guide for your 2004 Ford Truck Ranger 2WD 2.3L MFI DOHC 4cyl Engine Mechanical Specifications Torque Specifications. ... Ford Windstar 1999-2003 ... Bolts, Main Bearing Bolts, Rod Brearing Bolts, Crankshaft Damper Bolts, Flywheel Bolts, Manifold. Intake, Exhaust ... Vehicle: 2008 Ford F150, 98 Civic.
Dec 21, 2015 | 1998 Ford Windstar
What are the torque specs and sequence for the intake and head gasket on a 1999 Chevy Silverado 6.0l V8 K2500
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
30 N?·m
22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence)
30 N?·m
22 lb ft
Intake Manifold Bolts (First Pass in Sequence)
5 N?·m
44 lb in
Intake Manifold Bolts (Final Pass in Sequence)
10 N?·m
89 lb in
Intake Manifold Wiring Harness Stud
10 N?·m
89 lb in
Oct 27, 2015 | Cars & Trucks
I need the head bolt torque specs and sequence for a 2000 frd Taurus with a v6 3.0L flex fuel engine
Go to autozones website and make a free account, Log in and put in your make, model and year. Then look for free repair guides
Dec 11, 2014 | 2000 Ford Taurus
02 WIMDSTAR TORQUE SPECS INTAKE MANIFOLD AND SEQUENCE
always start in the middle, then work your way to the ends on alternating side bolts, bolts are probably 10mm or 3/8", if so around 18-24 ft/lbs torque maximum. don't use sealant on the intake manifold and the rocker cover should be 6mm or 1/4 bolts, same sequence just less torque, 10-12 in"/lb max
Jul 24, 2014 | 2002 Ford Windstar 3.8L Intake Manifold &...
Torque specs on intake plenum and fuel rail on a 98 ford Ranger with a 4.0l
Hi the torque spec for this fuel rail/manifold is 9-11lb/ft. Here is pic of the sequence.
Jan 10, 2012 | 1998 Ford Ranger SuperCab
Need the torque specs for the upper intake bults on a 2002 chrysler sebring conv. 2.7L
Fig. Intake manifold bolt torque sequence 2.7L engine
Upper intake manifold with a new gasket on the lower intake manifold and torque the bolts, in sequence, to: 105 inch lbs. (12 Nm)
Hope helps (remember to rate this answer). Good job.
Oct 11, 2010 | 2002 Chrysler Sebring
Need torque specs for a 2001 jeep cherokee intake manifold
Intake manifold using new gaskets. Torque the bolts, in sequence, to 105 inch lbs. (12 Nm)...
Fig. Intake manifold torque sequence-3.7 & 4.7L engines
Hope this help (remember comment and rated this).
May 07, 2010 | 2001 Jeep Cherokee
Need head bolt, intake manifold, and exhaust torque specs
Cylinder Head Bolt Step1- (25 FT.Lbs) Step2(45 Ft.Lbs) Step3(65Ft,Lbs).....Intake Manifold(35Ft Lbs)....Exhaust Manifold Center (20Ft Lbs) All Others (20 Ftlbs).....Thanks
Mar 06, 2010 | GMC Suburban Cars & Trucks
Need torque specs for for taurus
3.0L 2 valve 15-22 ft lbs
3.0L 4 valve 9 ft lbs
Jun 16, 2009 | 2001 Ford Mustang
Ford NOS 96 97 98 99 SHO Taurus 3.4L v8 Shortblock Assembly Logo
Top Ford Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Ford Tool and Hardware - Other Expert? Answer questions, earn points and help others
