Question about Samsung WF328AAW Front Load Washer
Washer leaks and smells like burning
Washer leaks from bottom of washer. Smell like a burning smell. Heard a pop like there were shoes put in it by themselves. Rubber around drum is chewed up like it frayed and some chunks of gasket missing from top of gasket. Rusting under rubber gasket at bottom. What may be the problem? How much would this cost to fix and can you DYI project.
  • michele capasso
    michele capasso Mar 26, 2014
    washer shot. The plastic piece that goes around the tub and connects to drain pump hose blew holes threw plastic. Metal pieces from the tub shattered and clogged the filter tub area. Not worth fixing. Wasn't anything i did, but life expectancy for front loads are only 5 years.
  • 3 Answers
Posted on Mar 24, 2014
SOURCE: when i opened my washer it smells like mildew.
With the washer empty, put in a cup or two of bleach and then run a complete cycle with HOT water and the HIGHEST water level setting. When the agitation first starts, wait a couple minutes, then turn off the machine and let it soak with the bleachy water for about 20 minutes - then turn it back on and let it finish the cycle. If it's REALLY a strong smell, add some Simple Green, or some other NON-AMMONIA detergent to the bleaching process. (Mixing ammonia and bleach together is a MAJOR no-no. It gives off nerve toxins. Very bad.) If you can't find Simple Green, then add some dishwasher detergent. Not dish soap, like Dawn or Joy, dishWASHER detergent like Cascade or Electrasol.
That should help.
If it doesn't help, then unplug the machine, turn off the water supply, disconnect the hoses, and pull the machine away from the wall. Check UNDER the machine for the problem... If the machine, or the hoses, or the drain have been leaking, the mildew smell may be coming from your floor or walls as they rot... If that's the case, you'll have to find and fix the leak, and then repair your floor and/or walls.
Also, check your dryer vent connection... When your dryer is running, do you get hot, damp air coming out from behind it? If so, the vent pipe connecton may be loose, in which case you probably have a build up of dryer lint behind and under both macines.. This can be a fire hazard (especially if you have a gas dryer) and if combined with a little water from the washer, can start to mildew and smell. Reconnecting the dryer vent correctly and cleaning under both machines may solve the issue.
Hope that helps!
Posted on Jul 10, 2009
SOURCE: my samsung wf448aap washer leaves clothes smelling
How much detergent are you using? Try using less detergent and softener in your loads. Too much detergent can leave clothes smelling similar to a wet dog, like you described.
Posted on Sep 05, 2009
VtToolMan
  • 704 Answers
SOURCE: Samsung Washer makes the clothes smell like mold
This can happen with any front loading washer, regardless of the manufacturer.
One of the first things to do is make sure you're using the He (High efficiency) laundry detergent and only use a small amount, about 3 tablespoons or less. The trick is to not use so much detergent that you start getting a buildup in your machine. Also, if you have heavily soiled clothes, pre-treat them instead of adding more detergent to your wash cycle. This alone will result in better results.
Also, be certain the washer is properly leveled in all directions and to make some slight changes in your wash day schedule.
By making sure the washer is properly leveled, it will operate better and help minimize odors, as the spin cycle will get more water out, etc.
The other tip, that has really helped in our house, is to do all the hot water (whites) as the last load. Since we do use bleach when we wash our whites, along with hot water, the washer's last load will have had the best sanitizing cycle run through it before being left for the next load another day.
With the bleach and hot water, the washer gets a nice clean disinfecting wash which helps eliminate odors, germs, excessive soap, etc. and leaves the washer fresher. By doing this, we don't have to purchase other (more costs and expense) additives to run through the washer to attack the odor causing germs and gunk.
What good is a more energy efficient washer if I have to always run a special tablet/liquid cleaner in it each week without any laundry in that wash load? Seems wasteful to me to be doing an "extra" wash just to wash the washer. So I'm not a proponent of having to always use another product every week or month to have a washer work like it should.
However, if you've got an existing (smelly/moldy) washer presently, I would recommend that you use a produce called Whirl-Out, which will help dissolve the buildup that your machine currently has and get it clean again. Then you can follow the steps above to keep it from causing you issues in the future.
I hope you find this Very Helpful and best regards!
Posted on Sep 21, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Washer makes clothes smell like dog
Hello there:
please follow these simple steps
Instructions Things You'll Need:
  1. Step 1 Balance your washing machine. Standing water breeds mildew and mold. A washing machine that isn't level to the ground stands a higher chance of not draining completely. Take a level and place it on the top of the machine along the front from side to side and then again along the side from front to back. If the machine is very off, you can adjust the feet to compensate or add something under one of the feet if it is not flat against the ground. Portable washing machines are especially prone to have standing water because they are moved around and not leveled each time.
  2. Step 2 Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine for an extended period at the end of the cycle, you will have mildew in your clothes and your machine. The same is true if you put clean clothes in the dryer and they are not completely dry when the cycle ends and you don't go back for a few days to pull them out. Damp clothes in an enclosed space for days will mildew.
  3. Step 3 Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
  4. Step 4 Use white distilled vinegar in an empty machine. Run a load with only hot water and two cups of vinegar to clean out the machine and freshen the scent. Vinegar naturally eliminates odors and reduces the buildup of soap residue in the washer which contributes to mildew development. You can also add baking soda and/or bleach to the load for both their sanitizing properties as well as assisting in ridding the smell of mildew.
  5. Step 5 Regularly use vinegar when you wash your clothes. Add 1 cup of white distilled vinegar to the last rinse cycle. Vinegar has acidic properties but it is mild enough that it will not harm your fabric. It does dissolve alkalines in laundry detergent which makes for cleaner and softer clothes. The reduction of detergent buildup in your machine will help to also reduce the incidence of mildew.
  6. Step 6 If you have a front load washer, they are particularly prone to mildew and mold. Follow the manufacturers suggestion as to how much and what type of detergent should be used. It is generally less than the traditional top load washing machines. Once again, additional soap residue helps to breed mold and mildew. Also, pull the seals back from around the door and make sure there isn't a build up underneath them that needs to be cleaned out.
  7. Step 7 Finally, if you have done all of the above and nothing seems to work there are commercial products available that are recommended.
Posted on Dec 26, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: The washer leaves water remaining in drum after
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
Posted on May 13, 2010
How come my clothes don't smell fresh?
Not the machine, stop using liquid soap. put machine through a cleaning cycle using a product like affresh.
Oct 10, 2014 | Samsung WF337AA Front Load Washer
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Washer won't wash or spin has a burning smell then shut off.
A burning smell confirms the fact that there is a serious fault . All what is required once the smell is detected is to remove the panel and check for the part that is heating up. You can first check the main motor, check for leaked capacitors, check if the smell comes from the control panel or the valves, pump.
since the smell is present the part will be heated up and so is hard to confirm.
Your observation to confirm is most important before we go to the next step as the damaged part thus detected must be replaced.
Oct 07, 2011 | Maytag PAV2300 Top Load Washer
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Mold Smell in front loading LG Tromm
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 15, 2007 | LG WM0642H
Samsung WF328AAW Front Load Washer Logo
214 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
