Question about Shure 55SH Series II Professional Microphone
Shure 55sh dead?
To make a long story short......... i sang in my shure 55sh and it worked great when i had finished singing i put it in my storage box,the next time i was gonna use it it was completely dead. i have opened the mic and solder all the connection points i even let an solder expert do the job one more time but it still won't work.what can i do? is there any way to open the cartridge? please help me i love this mic.
SOURCE: shure 55sh series 2 mic repair
Hi, I actually rebuild these mics and upgrade them. I'm an expert in the vintage 55's of all era's and the newer. If you are just looking to go back with the stock element of a 55sh2, or looking to upgrade your 55 vintage or new, with a SM58 a Beta 58, or a 87 Beta, I do all of that. All repaires from Hard mounted XLRs, screens, to polishing the surface back to new, or upgrade kits that you can put in yourself with my pictured instructions. Check out my web page at Mutantmics.com or google search Mutant Mics or conatct me directly at whoizitcc69@aol.com
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Posted on Mar 22, 2009
  • 611 Answers
SOURCE: Is there a way to open up a Shure Beta 58A?
Once you remove the grill, there is a C-Clip that holds the cartridge down into the handle. Use some c-clip pliers to pull the c-clip out of the handle. The c-clip will remain around the post on the cartridge, but that's ok.
Posted on Apr 15, 2010
  • 611 Answers
SOURCE: i have a shure microflex mic condencer 150 the led
The mic does not need a battery. But it does require phantom power. Contact the mixer manufacturer to find out how to turn on phantom power on your mixer.
Posted on Jul 15, 2010
  • 611 Answers
SOURCE: hello.help,i have a shure slx2 handheld
It will need to be sent to Shure for repairs. www.shure.com/service
Shure 55 sh dead?
You are best to send the mic to Shure for repairs. They can certainly get it working for you. www.shure.com/service
Mar 24, 2014 | Shure 55SH Series II Professional...
What's your problem? 55sh with 58 capsule ?
Look at the Super 55. It has a modified version of the Beta 58A cartridge in it.
Oct 09, 2011 | Shure 55SH Series II Professional...
Hi. I've connected my Shure 55SH to my netbook via XLR to 1/4", then with an adaptor to my 1/8" port. My recordings all have significant fuzz, but the level doesn't change when I adjust my...
Most likely the 1/8" jack's input is LINE level. The microphone works at a higher IMPEDANCE and will have to be boosted to line level in order to have a matching impedance to the input on your netbook. You can use a mixer, a DI box, or microphone pre-amp to match the LINE level of your 1/8" jack. That will give you more control over level with less noise.
Mar 01, 2011 | Shure 55SH Series II Professional...
I need a wiring diagram/schematic for a shure 55sh series II. it must be rewired. thanks lauren
There is a wiring diagram on page 10 of the User Guide.
http://www.shure.com/americas/products/microphones/classic/55SH-Series-II-iconic-unidyne-vocal-microphone
Dec 21, 2010 | Shure 55SH Series II Professional...
I have a two yr. old 55sh series 2 that just quit working. Looking inside the on/off switch cover, there are no loose wires. What to do next?
If you do not have experience in repairing these mics, you should probably have a pro audio technician do the work. The problem is an open circuit in microphone's internal wiring; either the mic cartridge is dead, or one or more of the fine wires connecting it to the microphone output connector are disconnected. Sometimes the fault is caused by a bad solder connection, or a faulty switch. As I mentioned, unless you have experience with these items, you can permanently damage a potentially salvageable mic. A goos tech should be able to identify the problem in a few minutes, and if the mic is repairable, it should be a cheap fix. Worst case scenario, a dead cartridge replacement may cost half the price of a new mic. But then, it's essentially a new mic.
Oct 06, 2010 | Shure 55SH Series II Professional...
Need cord for Shure 55S microphone
See the Shure website for the answer at:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=1012
Mar 09, 2009 | Shure 55SH Series II Professional...
Shure 55SH Series II Professional Microphone Logo
53 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
