Question about GE Profile Spectra JGB920 Gas Kitchen Range
I have a GE JGB920 Gas Range problem. One igniter does not work. How do I change out the igniter?
  • 57 Answers
Most gas ranges only have one ignitor (for the burners), so if one of the burners is not working, I would inspect the connection between the ignitor and the burner...not the igniter itself.
Posted on Sep 22, 2009
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: GE JGB920 Gas Range problem
if not post your email i will send you the service manual
Posted on Mar 15, 2008
IT TAKES A LONG TIME TO REACH 350 DEGREES ON MY JGB920 GE STOVE
most likely you have a bad ignitor,remove the racks,remove the floor to the oven,remove the flame spreader,put the oven on 350,if the flame doesn't lite within 40 seconds you have a bad ignitor.i looked up your model number,it shows a round ignitor but when i look up the part number it shows a flat ignitor,call your local parts store,give them the full model number that's on the machine,open the bottom draw,look at the left or right side of the frame around the draw opening not on the draw and you'll see the model and serial numbers,give them the full model number and they will give you the correct ignitor,let me know how long it takes before the flame lites
Nov 29, 2010 | GE Profile Spectra JGB920 Gas Kitchen...
GE XL44 (Model JGB920) oven seems slow to heat up and can hear the flame cycling on and off frequently. It is between 8 and 9 years old. Also, when baking, items near the back of the oven seem to cook...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 23, 2010 | GE Ovens
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Bake burner flutters
[ the glow coil } the ignitor is call needs replacing it'snot getting hot enugh to open the safety valve.it's no more then $45.00. Berry common problem.
Dec 09, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Mar 15, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile Spectra JGB920 Gas Kitchen Range Logo
276 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
