Question about Rainbow E series Canister Wet/Dry Vacuum
Water in the power head
I was vacuuming carpet and dumped over the canister unit. I immediately up righted the unit and shut it off. I noticed a small amount of water on the carper, retrieved a towel to clean it up. When I picked up the power head to continue my chores, water had puddled on the carper where the power head rested. I noticed water in power head. I am afraid to use unit now. How should I proceed?
    Habit-Forming:
    Scholar:
  • 60 Answers
Make sure machine is un plugged. Open up the power head that you are worried about and put some uncooked rice inside then close it back up, wait a few hours (or day if you want more reassurance). The rice will soak up any moisture trapped underneath anything or stuck in corners etc. Re-open use a cotton que-tip dipped in rubbing alcohol to clean the inside, electric boards and all, large surface areas that are not electrical could be cleansed in a less tedious way. Close it up again then try plugging in and turning it on. Watch for and smell for any burning signs, if you see or smell any turn it off and unplug it immediately. That is how to dry and clean any electrical device. Hope this solves the problem.
Posted on Mar 24, 2014
  • 4Help
    4Help Mar 24, 2014
    Quick note: if your cell phone ever gets to wet to work, I have seen this method work for cell phones without opening the phone up, just put it in a sealed zip-lock type bag with the uncooked rice. It will suck the moisture right out of the phone.
  • 4Help
    4Help Mar 24, 2014
    Also do not worry about drying the rubbing alcohol it will evaporate quickly.
RockyNR1
  • 324 Answers
SOURCE: Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Posted on Mar 21, 2009
  • 694 Answers
SOURCE: I think the power head
Make sure you have suction at the end of the hose. If not, the clog is most likely in the hose. Detach hose from vacuum and wand. Drop a coin into one end and allow it to fall through. If it doesn't drop out, the clog is definitely in the hose. Then visually check the wands for a clog
Disassembling the power nozzle is not necessary, or recommended. First, ensure the clog is in the power nozzle. Drop a coin in the wand end and see if it falls out. If not, the clog is elsewhere. You should be able to clear the power nozzle by disconnecting the wand. Use the handle of a table knife to try to push the clog back through the power nozzle, toward the brush. If that doesn't work, try using long nosed pliers to clear the clog.
Posted on Jan 04, 2011
  • 41 Answers
SOURCE: my rainbow e-series canister vacuum
Get a new hepa filter.
It is at the back side of it, behind that rectangular cover, where the exhaust cover is. It either snaps off with two plastic tabs on the bottom of it, or has two screws on the bottom of it, and two screws behind the cord holder taps thing. If it is that kind, the cord holder tabs thing, snaps off with a flat head screw driver on either side of it. You will see the little slots on it, if it is the kind with the screws on the filter cover. Two screws behind the cord holder tabs thing, towards the top of the filter cover, and two on the bottom of the filter cover.
Always clean your water separator with a tooth brush, or Rainbow separator cleaning brush. If it has it, it is by the water separator in a special slot for it, rite there by the water separator. If not, use a tooth brush. They are just alike. The separator nut, is a half inch, or 13 milimeter size of a nut.
Thank you,
Ralph
Posted on Jan 12, 2011
  • 99 Answers
SOURCE: Rainbow Series E is leaking. Not sure if water is
empty the water bin out and dry the machine inside and out with paper towels. get it all extra dry. then put the machine on a hard flat surface with newspaper under the machine. next start adding water one cup at a time. after each cup is added wait ten minutes and check the newspaper for water spots. note how many cups were added before the leak was detected. if the leak apears after only one or two cups of water are added then the leak could be in the very bottom of the water bin. if so a good way to fix water leaks is using plumbing goop. this is a very good product that stops leaks and stays in place. if you don't have a leak after the first two cups then the crack must be higher up. keep adding water one cup at a time until the leak is noticed. if it doesn't leak start the machine up after it is full of water and leave it on the newspaper. you need to notice where the water is coming from and then try to fix the crack with plumbing goop. follow the instructions get everything dry then put on a layer of goop not real thin but not over about 1/8 of an inch thick. let it completely dry then refill and check for leaks. the plumbing goop is available at the hardware store and is a wonderful product that really sticks and bonds. it should fix any leak.
Posted on May 03, 2011
mc1bean
  • 3053 Answers
SOURCE: have no power to canister. vacuum wont run. but
Hello, benn
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my own personal time
to see if I can help. Even though this a Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about vacuum cleaners and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just tried to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry.I do not get paid to help people on the site, I do it cause I like to help.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 30, 2011
Is it safe to dump dirty water in toilet?
It would be best to dump it outside because the carpet fibers, (I call them carpet dumplings...lol), may get caught on something in the drain and eventually get stopped up.
Jim
Aug 13, 2011 | Rainbow E series Canister Wet/Dry Vacuum
The power head on my vacuum keeps shuting on and of when vacuuming carpet
the electric cord may be loose on the head. I have had this happen on my other power head vacuum. you may not be able to fix it.
Aug 12, 2010 | Filter Queen Majestic Canister Vacuum
My electrolux O3 carpet power head keeps shorting
If your unit is like ours, there is a electrical short in the wand to Hose connection.. dont use it.. ours unit shorted out and sparks were everywhere.. burned thru the wand to the inside of it and the outside. Good thing my lovely wife wasn't touching that part. electrocution risk was Extreme. PESTER ELECTROLUX, they drag their heels when it comes to admitting and making it right.
Oct 18, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Canister vacuum keeps turning off, can push buttons on wand handle to restart but shuts off again as soon as you start to move handle
its sounds like the problem is either the power head wire which when your using it and twisting it left and right, turns it off.. Or it could be in the hose where the connect meets with the unit.
Here's a number to call to further assist you. 1-800-322-2965
Aug 14, 2009 | Miele S548 Bagged Canister Vacuum
Kenmore vac won't shut off, blowing heavy air from vent
For the stack of problems you have, it sounds like it be best for you to ditch it and get a new vacuum. The heavy problem sounds like a motor issue. The burning smell is most likely from the belt being loose on the power head.
Economically, you should just get a new one instead of replacing the whole system guts
Aug 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Feb 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Rainbow E series Canister Wet/Dry Vacuum Logo
50 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
