Question about Continental Manufacturing Company Value Line CPT92 Stainless Steel Commercial Refrigerator
What setting should my ranco pressure switch be set at for my continental cpt92 refrigerator
Not sure if my settings are correct. top of fridge not getting cold
  • 44 Answers
If it's for "refrigerator" temps 37 to 40 . 37 lb cut in with a 12 degree differential. On a R12 system. Is this what you have ?
Posted on Mar 25, 2014
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
Ranco k series
You need to take that control to a refrigeration supply house and get the proper control replacement. Those are factory set. One is differential and the other is set for temp. The adjustments in the field just don't stay put and will fail after messing with them. Ranco has a book that the supply house has that will give you what you need and the part is generally on the shelf. Hope this helps and good luck.
May 16, 2014 | True Refrigerators
Plugged in our 19 cu ft Kenmore black/stainless steel refrigerator (top/bottom) and the freezer is working but the refrigerator is not cooling. It's been pugged in for an hour now and doesn't seem any...
Hi!!
Make sure the temp. settings for the fridge are set about half way, check that the small fan on freezer is working. The fridge gets cold by the air that the small fan blows thru a duct on the inside back wall of the fridge. If the temp. setting for the fridge is set too low, only a small amount of air goes into the fridge, find the vent(s) and make sure air is circulating. It is not uncommon to accidentally move the temp controls when you clean the unit.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Apr 02, 2011 | Kenmore 64802 Top Freezer Refrigerator
The fridge is not getting cold
Just check and fix below : - Refrigerant pressure ( need to top up if found low pressure) - Wrong set of thermostat ( set it to middle or a bit colder)
Regards
Dec 19, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
The refrigerator is not running cold.
most fridges are operating best at +(plus) ,-(minus)3.5 degrees C, at what setting do you have it currently? (settinngs can be between 1(one) up to 10(ten) depends on model and make). most people realize that the fridge is not cold and set the settings(fridge control) up, that is wrong, try to keep freezer build-up clean and run the fridge on a setting of 1(one). switch of the mains, clean the fridge and follow above instructions. if the problem still exists after that then you need to replace the gas
Dec 12, 2010 | Maytag MTB1954ME Top Freezer Refrigerator
Fridge is too cold even at lowest setting and freezing drinks.
The thermostat sounds like it is out of calibration and stuck closed. A good replacement would be a Ranco A12-1560 mounted in the evaporator (cold) coil.
Nov 07, 2009 | True TBB-3G-S Commercial Refrigerator
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Continental Manufacturing Company Value Line CPT92 Stainless Steel Commercial Refrigerator Logo
76 people viewed this question
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
