Question about Dryers
GE dryer willl not stop, drys OK
I have a GE Dryer model #DDG7180RAL that drys OK but will not shut off.  The timer does not move at all.  I originally believed that the timer was/is bad, but my wife cleaned out some built up lint (beyond the lint screen), and the timer worked for a few times.  It has sense stopped working again.
Is this the timer or a lint/vent problem?
  • 240 Answers
I does sound like the timer has went out on your dryer, but there could be other problems as well.  Sometimes exccesive lint build-up can cause a heat transfer issue with the thermostats.  On GE models, anything o stop or delay heat transfer could cause the timer to stop working.  If im not mistaken, this is a gas dryer correct?  It could be a number of things that could stop the forward motion of the timer, primarily a stuck or inoperative thermostat, a defective flame sensor (highly doubtful if it dries), or a wiring problem.  Be sure to check out all your wiring, then if you wanted to, try and replace the thermostats.  Just dont want to see you waste a lot of money if it was a bad timer.
Posted on Oct 31, 2007
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
The dryer drys but the dial does not move and....
HI. the timer control module is experiencing difficulties. the advancement of the timer dial is crucial, and it must rotate in order to initiate proper cycle sequence. The timer motor is the culprit in this case, and the timer will need to be replaced.
Replacing the timer will fix this issue.
Sep 09, 2009 | Amana DLE330RAW Electric Dryer
Dryer shuts off shortly after starting it, model dwsr483eb2ww , ge, electric
Have you taken the vent off of the back of the dryer that attachs to your house? When you detach the vent run one normal load and if it drys fine then it a vent issue with your house and not a failure with your unit. Email me back if that doesn't fix it.
Aug 20, 2009 | GE DWSR483EBWW Electric Dryer
GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Aug 09, 2009 | Kenmore 800 6983 Electric Dryer
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
May 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryer timer was working
because there is a door switch that would turn your dryer off because of safety issue.
tnx 4 using fixya,
Oct 04, 2008 | GE DSKP233EWWH Electric Portable Dryer
Dryers Logo
281 people viewed this question
Top Dryers Experts
