Question about Frigidaire FFU14F5HW 13.7 Cu. Ft. Upright Freezer
My FFU14F5HW is freezing and the inside light is on, but the temperature control is not working. Is there a reset for me to do for it? I don't want to call a repairman if it is freezing, but I also
Standard electronic temperature control not working. Everything else is working.
  • 884 Answers
Is it never switching off? There are no "standard" electronic controls, each maker has different ones.In what way is it not working, exactly?
Posted on Apr 26, 2014
Testimonial: "The freezer works normal. I am unable to adjust the temp since the display is not working."
  • mike cooper Apr 27, 2014
    I would recommend calling a technician in that case. So difficult to diagnose faults like that over internet!
How to install door lock?
Hey Joe, thank you for your inquiry!
I see that you need assistance installing the door lock on your Frigidaire freezer, FFU14F5HW. I was able to locate the parts schematic for you and on page two it provides you a picture of the components for the door lock. I hope this information helps you with your part installation. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/StCloud/5995626933.pdf
Dec 31, 2015 | Frigidaire FFU14F5HW Frost Free 13.7 Cu....
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
What freon to use
Hey friend, thank you for the post!
I understand that you are searching for what type of freon is used in your Frigidaire freezer, FFU14F5HW. Based off of that model the freon would be 134A. Hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire FFU14F5HW Frost Free 13.7 Cu....
Frigidaire FFU14F5HW Hi-Temp alert. Checked thermistor at front panel pins 1 to 2, reading was 162.8K ohms. Removed panel to check thermistor, then put it in a cup of ice water-now reads 32.1K ohms. P
Check the internal temp with a thermometer. Anything above -12c will give you the hi alarm. Check the condenser is clean and drier not too warm, no ice build up inside the evaporator and all fans working properly etc, before suspecting thermistors.
Apr 02, 2014 | Frigidaire FFU14F5HW 13.7 cu. ft. Frost...
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
The temperature keeps on rising. everything inside is melting. does not freeze anything. fan and light is working.
Turn it off, defrost it for a couple of days """""with the door open""""", restart it with door closed and see if it starts freezing again after about 2-3 hours, if so, then the draw unit works, that indicates the defrost cycle needs to be reset or one of the defrost elements has failed causing the rest no to do anything. Any probs call me on 08 9523 0552 Russ
Feb 27, 2011 | True 31 cu. ft. / 878 liter Upright...
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
My fridge freezes everything
If the temperature outside the refrigerator drops below the temperature inside such as in a non heated garage the things in the refrigerator will freeze. Short of moving the refrigerator to a temp controlled place there is not much you can do about it.
Jan 07, 2009 | Freezers
Frigidaire FFU14F5HW 13.7 Cu. Ft. Upright Freezer Logo
148 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
