Question about SkyGolf SkyCaddie SG4 GPS Receiver
Screw stripped screw which connects power for recharging has striped after 3 years of use. Is a replacement available. Sky caddie wants to send in unit for repairs (during golf season - get serious!)
The problem is that the screw is not stripped. The female end in the unit is made of brass, which is weaker and ususally is the part that strips, so buying a new screw is not usually the answer. A quick fix is using a spring operated clamp. The clamp is in the shape of an A, usually they are black plastic with 2 swivel orange tips on each end. You can get them at any hardward store. Buy the 6 inch long one, they cost about 2 dollars. Open the 2 orange tips out and clamp the back of the connection on the cord and on the top front of the unit. There is a small bump at the top front of the unit that will help hold the clamp in place Be sure that all of the prongs are lined up and touching the unit. You may have to wiggle the clamp around a little to get the cord to line up correctly. When you think it is connected solidly, gently set the unit down, plug it in and turn it on. If it is connected solidly you will see the battery indicator show it charging. I have been doing this for a couple of weeks now and it has become quite simple. It sucks to have to do this, but it works.
Posted on Jul 23, 2010
  • dwthoreson42 Dec 04, 2010
    Great suggestion, I just did it and now I am charging just as you said. It may ****, but at least I am not throwing away the unit just because they do not know how to make a simple connection. I am very unhappy with them as a company, they stink. They offered to sell me the SG5 for a couple hundred bucks more, why would I give them more money for a design flaw in their product?
    Thanks for taking the time to post this.
    Don in Ocala
  • dmcf43 Aug 17, 2011
    Clamp sounds good, was on a golf trip when this design flaw reared its ugly head. Used rubber bands to hold the contacts down. It worked and will continue using this method. Sending back for repair does not sound like an option. Would not buy another. Good golfing everyone.
    Don in Michigan
Replace hard drive
Simple fix. Just remove the power cord, remove the battery, then remove the screws from the cover that houses the hard drive on the bottom of the laptop. Most times the cover will have the icon of 3 or 4 circular discs on it to represent the hard drive. Once you have the cover removed, there might be screws that hold the caddy inside the bay, if so remove them then you can lift the drive and caddy out of the bay. The drive might be inside of a caddy with screws holding it to the caddy. Remove the screws from the caddy and then you can remove the drive.
Notice what type of interface (IDE or SATA) your drive is and replace it with the same type of interface drive. IDE Drives have about 20 or so metal pins or prongs that stick out. SATA drives have two small plastic looking pieces that connect it to the interface inside the bay.
May 31, 2012 | HP Pavilion N5425 Notebook
How to remove hard drive
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Pavilion dv4 1431us how to remove the hard drive. Don't know which section is the hard drive screw to unscrew.
The Battery Compartment Cover is to the outside.
(By the way. Have all power sources removed from the laptop. The AC adapter {Charger}, and the Battery)
Laptop upside down, face the Battery Compartment to the top.
The long middle cover in the middle, under the Battery Compartment Cover is the Harddrive Compartment Cover.
On the Left side of the Harddrive Compartment Cover are two screws to remove. One in each outside corner.
After the screws are removed, lift up on the Left side to remove the cover.
(They may just loosen to a loosened state, and not actually remove)
The Harddrive Compartment Cover is 'hinged' on the right side, with a couple of plastic tabs coming from the cover itself. After it is tilted up far enough so that these tabs will come free from the slots they're in, the cover can be removed.
There are 3 screws which hold the Harddrive Caddy in place. (The Harddrive is mounted to a sheet metal Caddy, which goes across the top of the Harddrive, and down each side)
The first screw is in the Middle to the Left outside.
The other two screws are on the Right, and are on the corners.
After removing the screws you will see a Black strip of cloth/plastic coming from the Left side of the Harddrive/Caddy combo.
The Harddrive is eased up slightly on the Left side, and pulled to the Left side with the strip of cloth/plastic.
(On the Right side of the Harddrive is the interface. The pins that come out of the Harddrive. These pins insert into a female socket in the laptop)
The Caddy around the Harddrive is mounted to the Harddrive with 4 screws.
Two on EACH side.
Holding the Harddrive in the direction it came out of the laptop, (Interface pins to the Right), look at the mounting screw on the Right side.
The one that goes through the sheet metal Caddy, and fastens it to the Harddrive.
Now look at the same screw on the Left side. It goes through a tab.
Remove these screws, and DON'T loose them, or mix them up with the other screws.
(Use a multi-compartment container. You can use a clean egg carton in a pinch)
Remove the screws from the other side.
Install the new harddrive in the Caddy, then install the Harddrive/Caddy assembly in the laptop.
DO NOT overtighten the screws.
Regards,
joecoolvette
Oct 18, 2010 | Computers & Internet
The screws to put the crib together are stripped need new ones cant find it is simmons natural meridian collection bought about 4 years ago
if the threds are striped on the screws,,,,or are they "bolts?"
what are the threds like in the nut holders? if there striped as well,,,you need to replace the lot!
Aug 21, 2010 | Toys
How do I download skycaddie program back on to the computer. I already have a subscription for the year
THIS HELP YOU
http://wareseeker.com/free-sky-caddie/
www.skygolf.com/ -
Sky caddie Free Download,Sky caddie Software Collection Download. ... English and Dutch versions avilable.sky caddie. foxfire mail, Download now ...
www.brothersoft.com/downloads/sky-caddie.html -
Mar 01, 2010 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How to change hard drive on acer aspire 1410 ?
Hello
Here is some steps you can follow to change/replace you HDD.
Step 1: remove power cord, and battery
Step 2: flip computer upside down
Step 3: find the hard drive bay, there might be a cylinder like icon near it, and it will be close to the front of the system.
Step 4: remove the screws, likely 2 screws.
Step 5: on removing the plastic lid you will see a metallic box, with a plastic strip on top of it.
Step 6: on the side that has extra space there will be 1 or 2 screws, undo these
Step 7: pull the plastic strip toward the side of the computer that has space open and the whole caddy should pop out.
Step 8: take the 4 screws out of the side of the caddy and the hard drive will just slid out.
Step 9: just put new one in the same way the old one was. and reverse the steps and put your recovery disk in to install your OS.
Hope this can steer you in the right direction.
Do not hesitate to let me know if you do not understand.
Kind regards
Andrea
Jan 10, 2010 | Acer Aspire 1410-8414 Netbook
Replace cdr-rw drive
Open the side of the mac. The optical drive caddy is held by 2 screws.One is on the lower edge of the caddy approx. 2/3 of the way towards the rear end. The second is at the top of the caddy fixing into the front of the case. Remove the rear cover plate from the caddy by sliding it towards you. Slide the caddy towards the rear of the computer, this will then allow you to remove the cables from the drive and remove the caddy from the computer. Remove the 4 mounting screws from the optical drive (2 on each side) and remove the drive by sliding it out forwards. Replacement is a reverse of the above procedure.
Jun 09, 2009 | Apple Power Mac G4 Desktop
SkyGolf SkyCaddie SG4 GPS Receiver Logo
604 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
