Question about Kenmore Elite C970 440935
Kenmore c-970 setting clock
There is no 'clock' button
    New Friend:
Tap Clock sign (cooktop lockout) then ->
Enter time 8 - 3 - 7 for 8h37 ->
Tap "Start"
Done...
Posted on Nov 20, 2015
What does Fault code F10 on a Kenmore Range, Model #970-678421, mean please?
run away temp either temp probe or EOC board is the problem
Jan 30, 2017 | Kenmore Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Kenmore 970 will not heat up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 13, 2010 | Kenmore Ovens
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
Kenmore oven does not go on at all.
If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Nov 20, 2009 | Kenmore Ovens
My step daughter has pushed some buttons on the oven, and now it is locked.....it is a self cleaning Kenmore convection oven......how do I unlock it?
DON'T KNOW YOUR STOVE BE HERE IS AN SIMPLE FIX THAT MIGHT WORK ADVANCE THE TIME ON THE CLOCK 8 HOURS AND SET SEE IF HELPS IF NOT TELL ME MORE
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Elite C970 440935 Logo
119 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
