Question about Vehicle Parts & Accessories
I have a 2005 kia spectra i changed the speed sensor on it then my speed odometor and milage stoped working whats going on?
Needing to know why my speed odometer isn't working also my mileage stoped as well
  • 34 Answers
Check connector and you could use a tester and back probe it and try positive and negative and have somebody sit inside the car they should see it moving up and down if not,their is a wire cut or probability is cluster does not work and also if speed sensor or connector was the problem check engine should be on indicating that their is problem.
Posted on Apr 23, 2014
I am trying to find where the oil temperature sensor is located on a 2005 Kia Spectra. I have a P0198 error code
Dear Eojamio,
First, call you local Kia dealer and ask them.
I checked and I found there is no oil temperature sensor on your car.
There is a oil pressure sensor.
There is also a coolant temperature sensor.
Any Kia dealer should tell you 1) what the code means, and 2) where the sensors are located.
Know that you may not be able to see them, even with a flashlight, as they are often "buried" in spaces around the engine compartment.
God bless your efforts.
Apr 17, 2017 | 2005 Kia Spectra
2005 kia spectra Lx speedometer drops to 0 miles per hour when go over a bump ,i already replaced the speed sensor, now what
Off to a repair shop to have the car diagnosed
to find the problem,can't guess at it or keep
installing parts until you do some testing & find
one that has failed
Dec 09, 2014 | 2005 Kia Spectra
What do I do i replaced the engine in my 2007 Kia Spectra with an engine from a 2005 it idles good however it will not speed up what do I need to check for now?
i believe your vehicle has a speed sensor as well
as that throttle position sensor. If you did replave
the throttle position sensor, did you make sure
you put the new one back in the exact way you
pulled the old one out? There may be a camshaft
sensor giving you a problem. There are several
sensors that may have something to do with that.
Jun 28, 2014 | 2007 Kia Spectra LX Sedan
2005 kia spectra blower only blows 1 & 4 speeds
Could be the blower motor resister,it's located by blower motor,2 screws hold it on,easy to remove,click here to see part.
Dec 30, 2012 | 2005 Kia Spectra
My 2003 Kia spectra overdrive stoped working. it used to sometimes work then it stoped. The light on the dash that says if i'm in overdrive or not does not even come on any more. what can I do to solve...
You may just have a dash light burned out. While driving over 50 mph you can activate the switch on the shift lever (it's a push button) and even if the light doesn't come on in the dash you should be able to see if you are in overdrive (will speed up) or if you just took it out of overdrive (slows down or motor runs faster at the same speed).
Jan 09, 2011 | 2003 Kia Spectra
I have a 2005 lexus rx330. the odometor stopped working. how do I fix it?
check and see if your cruise control still works your problem probably lays with in a speed sensor you have an output vehicle speed sensor that can cause the problem and i say a vehicle speed sensor because you didnt say anything in reference to having a abs ight on on your dash if you do have that as well you could possibly need a wheel speed sensor as well but i would lean more towards vehicle speed sensor output sensor
Sep 28, 2010 | 2005 Lexus RX330
I have a 2005 Kia Spectra.I have 67000miles on it. I was told, because of the milage I need to change the timeing Belt. Will it give me a warning?
Yes, Kia's recommended replacement is at 60,000 miles.
It's the type of thing that if you plan for it and have it done, you won't find yourself broken down and wishing you had done it.
Nov 04, 2009 | 2005 Kia Spectra
2002 kia spectra wont starts off in drive and wont
try checking vehicle speed sensor & transmission nutral switch
Jun 21, 2009 | 2002 Kia Spectra
Speedometer stoped working
Is your Speedo meter has Cable Type pls Lubricate your cable. If you have sensor Model Pls Check Wire Connection.
Jun 01, 2009 | 2003 Kia Spectra
Locating and replacing the o2 sensor on a 2005 kia spectra
a wrench and just unplug the sensor wire and screw out and install new one. they make a special socket but i just use a wrench.
Sep 11, 2008 | 2005 Kia Spectra
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
