Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Can't balance pedestal for washer
Can't take drawer out
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Electrolux pedestal drawer won't close
Good Afternoon Apetgroomer,
I see that you're having trouble with your Electrolux pedestal drawer, model# EPWD15TS, door not closing. There are 2 pieces inside the drawer that help to keep the drawer shut that could be broken. One is the drawer strike, which is actually attached to the drawer itself. The other is the drawer actuator, which is attached to the casing which holds the drawer. Check both of these parts, and if it is one of them, i suggest contacting the manufacturer to se if they have any replacement parts.
-Best Regards-
WP
Apr 02, 2014 | Electrolux 15 Turquoise Sky Pedestal...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Washer is off balance. Need to get to levelers.
I had the same problem...thanks for posting a solution. I agree with the solution posted above, but on my unit they are 1/4" HEX head screws, not phillips. Look at the illustration on page 4 here for help:
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/XHP1550VB_Installation%20Instruction.pdf
I hope that helps.....
Dec 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Balancing the washer on the pedestal
Yes, ljharlow,
What is your Question?
You have a problem balancing the washer on the pedestal??
You must first balance the washer and then put it on the pedestal!
I take it you bought and picked up an installed your own machine.
The delivery men know to do the leveling foirsy and then raise them on to the pedestal
If you have two people you can have one person lift the front of the machine by tilting it back wards on the pedestal so the front goes up in the air a little and the second person turns the adjustable legs till it is level! If you laid the washer on its side ,front,or back at any time since you bought it then you threw the machine out of balance and YOU DO need service to correct this situation!!!!!!!
bless you Huuum
Please rate me on our site for my good advice before you sign off
Sep 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Jul 31, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Jan 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
