Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer wont do anything!
Yesterday the lid latch wouldn't recognize that it was closed during a whitest whites cycle. today it wont do anything, not even rinse and spin. it just comes on and hums. it is leaking water everywhere.
    Sergeant:
  • Whirlpool Expert
  • 243 Answers
It could be the lid switch, i had similar problem, changed the switch, helped for a day, changed it again, same...So then i did a diagnostic test. it said that it was the main control board,changed it ($135), didn't help. I noticed that was a little bit of water on the floor under the shifter, changed that, worked for a while, then i noticed that it was wet again. I traced it to worn bearings that the tub spins on which wore the tub seal and made water leak on the shifter electrical connection, Changed the bearing which is the whole transmission and comes with new tub seals. It stopped the leak and has been working for more than a year.
Posted on Apr 11, 2014
  • 1462 Answers
SOURCE: Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
Posted on May 02, 2007
SOURCE: Duet washer leaks during use; rinse cycle?
I am having the same problem with my Duet and would like to know if you will send me the link? nitewind44620@yahoo.com
I have found socks in the boot and I thought that solved the problem which was a tip by someone, but my wife says its still is leaking from time to time. Would like to see what this entails on the change and the cost of the seal. Thanks for help in advance.
Posted on Jan 28, 2008
  • 57 Answers
SOURCE: Humming noise during spin cycle
call a repair man and have him change the drive block. it is about 30 for the part
Posted on Feb 16, 2008
SOURCE: Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Posted on Dec 08, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Washer wont spin
The safety latch could be worn or stuck, the lid not closing tight enough to disenage the safety lever
Apr 20, 2013 | Washing Machines
I have a Kenmore 80 Series Washer (Model # 20802990) and it was working fine yesterday, and today it will go through the wash, fill up and go partway through the rinse cycle and then stops. It wont drain...
the lid switch is broken this video will show you exactly how to replace it....
http://youtu.be/MFsvLiuTniU
the part#for the switch is 3949238 you can order it by going to searspartsdirect.com or look in your local phone book and find a parts dist. in your area
Jul 20, 2011 | Kenmore 24032\24036 Top Load Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops during rinse cycle
if unit is stoppin in rinse cycle and not advancing into drain/spin mode. you lift the lid and its stalled full of water??? clos the lid again and listen for a slight "clicking" noise, chances are you lid switch has gone bad, and the machine does not recognize the door being closed, and for safety reasons will not drain/ and or spin..very common issue!
Jan 27, 2010 | Kenmore Washing Machines
Will not drain/spin. Yesterday, the load was out of balance...
Try unplugging the washer and let the curcuit board reboot. Unplug for 5 min. Then try moving the selector to spin to drain the washer. Sometime selecting too many modes trying to get something working can confuse the electronics. Reboot the curcuit board and try just spin cycle.
Apr 29, 2009 | Washing Machines
Whites are not white
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Apr 10, 2009 | Kenmore 44102 Front Load Washer
Won't run
Most washers today will not do anything after fill unless it sees the lid switch (innerlock system) closed. The same as having the lid of the washer up during a wash cycle. They will fill but until the timer, or ECB gets a signal back from the pressure switch (water level switch) it will go no further. Some of the electronic machines will also time out in the fill cycle because of a lack of water flow. The fill cycle is a timed event and if the water level switch ( controlled by the ECB ) does not close in the time alloted, it will stall. This can be checked by hitting the start button again. Most of these problems are caused by a lack of water flow on the initial start up. Cleaning your water inlet screens in the supply hoses and screens in the mixing valve itself will solve this issue.More information to the specific model would help pin-point this problem.
Sep 19, 2008 | Maytag LSE7806A Top Load Stacked...
Washer lid will not open after cycle
suspect bad lid latch there is usually a 4-6 delay after washer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
May 22, 2008 | Kenmore 98702 Stacked Washer/Dryer
Wont start
Give it a firm push over the door latch once you've closed the door..it might be the door switch not activating. oops.... first and formost isolate from power for 5-10mins and try
Dec 28, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
