Question about One For All Televison & Video
Don't have remote
How do you switch the component over with out the remote?
    Top Expert:
  • One For All Master
  • 75,591 Answers
Without a remote control, you can't select its inputs.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Mar 25, 2014
I have Honeywell st6400c. The heating runs all the time although I have switched off the programmer. I have just replaced the wired thermostat with a remote one. Could the wiring be incorrect
Start from scratch and do t hardest thing there is for any man to do......................STUDY the directions for the new components.
Sometimes it's THAT simple to correct a mistake. don-ohio (:^)
Jan 16, 2017 | Honeywell Heating & Cooling
Hi my name is Ricardo something wrong with my television the buttons on my remote does not work even the buttons on my television don`t work neither the only button that does work are the on and off b
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 08, 2014 | Televison & Video
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
Remote stopped working. How does one reset the remote?
Programming a code into a remote mode:
  1. Turn on the component to be programmed, then press the corresponding MODE button on the remote control. (TV, VCR, AUX, CABLE, ETC)
  2. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control.
  3. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming codes for the corresponding component can be found on the following website. Again, if the code is correct, the device will turn off.
  4. Press the MENU button to store the code. After blinking twice, this code is stored.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Hi i have play station 2 and i don't know what to put the tv on to play my games
Well first if you don't have a factory remote you will have to purchase a universal remote that supports i'll products program using factory codes or do a manual search( which takes a little time but I have had better luck with for more functions ) after programming you press tv/vcr button in which it should display ant. vIDEO1 video 2 and component repress button until desired chann el is highlighted coincideing with whatever location you have your device connected rear is video 1 and multicolor is component and front is video2
May 18, 2011 | iLO IWT3206 TV
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Remote problem
You get lucky once in while right?-lol
You need to do 1 of 2
get universal remont-are use the 2 you have but be sure you enter the source button on both-
Sep 05, 2007 | Samsung AH5901169L Remote Control
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
I lost the instruccions, I know my Tv code for it, but I don´t know the steps..
these claim to be the instructions - sorry no luck with a manual 1. Turn on the component 2. Press and hold the component key (TV, DVD, VCR-AUX, SAT-CBL) The illuminated on-off key turns on and stays on 3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off. 4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on. 5. Release both keys. The illuminated ON-OFF key remains on 6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.) 7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved. 8. To confirm that the component is programmed with the correct code for max functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work try programming the remote with a different programming method. Be sure to retrieve the code your remote programmed. here's the link there might be other useful info http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7713 Hope this helps :)
Jan 12, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
15 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
