Question about Chauvet CHVT-SLIMPAR64 - SlimPAR 64 RGBA LED PAR 64 with a
Can't program Chauvet SlimPAR 64 RGBA
I program the light fixture for DMX mode and set the channel but it will not respond to my controller and acts as thought it is in some kind of automatic mode.
  • James
    James Mar 25, 2014
    Hey guys I think I figured out what is going on. Apparently DMX channel 1 isd used to put the SlimPAR 64 in slave mode. If you select DMX 4-CH or 8-CH and then select channel 1, the unit is in slave mode and will not repsond to a light controller. Thanks for checking it out for me.
2 Suggested Answers
  • 5603 Answers
SOURCE: using 24 chauvet par 56
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Posted on Apr 28, 2011
Testimonial: "Thanks fredy2 !!!!"
I have mine on the dmx setting for it to turn constantly and it's stopping and starting irratically flashing on and off so I'm getting hardly any effect from it at all I'm thinking it's a problem with the...
I am not sure if you are using a DMX controller or a standalone setting. If on standalone, sound triggers a random reversing, stopping and flashing mode. I am NOT sure that a stationary mode is available without being commanded by a DMX controller. If you are using a DMX controller get back to me and we will analyze what the problem is. If using a DMX controller, tell what address you are using and the length of the control cable.
May 01, 2011 | Chauvet 2) Chauvet Double Derby X Dmx Led...
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
When i turn on the brand new double derby it works for 2 seconds and then goes off, what could this be and how do i fix it please Lily
It is probably in the wrong mode. Since the light can be set for automatic, sound, and DMX we have NO idea what mode you are trying to run. Refer to page 8 and 9 in your manual for correct dipswitch setting for whatever mode you are running.
For eye protection, the lights must keep moving or they will shut down... which is likely what is happening in your case. If you put in auto mode or sound mode they should keep on. If in DMX mode and the mode does not command movement all the time, they will extinguish.
Mar 13, 2011 | Chauvet 2) Chauvet Double Derby X Dmx Led...
The red and green control channels are linked. When I bring up just the red channel on the light board, both red and green channels move together. Same thing happens when I move just the green channel. ...
It appears from the manual that 00 is 100% full intensity just as you are observing... I can understand how you would be confused by the way it is written in the manual...
It also looks like you have to set chan 1 to be between 0 to 29 to select the RGB mode...and ALSO those color intensity values are "upside down", that is, 00 is full on for each color. and 255 is off.
These manuals can really be confusing.
Mar 08, 2011 | Chauvet Led Colorsplash 200b Dmx Wash...
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
I have numerous Chauvet 200b LED lighting fixtures. The problem I am having is: the "blue" LED"s on most every fixture are starting to go out. All the other colors are fine (it's just the...
Before jumping to conclusions, one should do some testing. It is posssible that you are having a DMX data error. If your lines are long, please review the need for a termination resistor at the far end of a DMX chain. The reflections of the data pulses can confuse or cause errors. Test a unit up close to your controller so the cable is short. If that magically works, install a terminating resistor.
Beyond this, electronic testing needs to be done. I did find in a Chauvet LX5 a bad solder joint at a connector that brings the power for, in my case, the green LED's. There will be surface mounted resistors on the back of the board that limit the current to groups of LED's.
If the whole fixture loses the blue at once, either suspect a DMX error or the driver in the fixture.
Mar 02, 2011 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
Just got a Chauvet Trident and plugged it in and the moter tunrs left then right , then stops ? The LED's blink 1 time then that is it ?
The left right motion is when the motor calibrates its position. The unit is then waiting for input... try generating a loud noise... if the audio gain is up and it is configured for manual rather than DMX it should start.
Dec 24, 2010 | Chauvet Brand New Chauvet Trident Dmx-512...
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
Chauvet CHVT-SLIMPAR64 - SlimPAR 64 RGBA LED PAR 64 with a Logo
93 people viewed this question
Top Chauvet Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
gamehouse8888
Level 1 Expert
 steve
steve
Are you a Chauvet Event Planning and Celebration Expert? Answer questions, earn points and help others
