Question about Sanyo Taho Scp-4100 E4100 Sprint Rugged Mil-spec Bluetooth 2mp Camera Cell Phone
Charging port is bad sanyo taho
Charging port is bad can i replace it
    Master:
  • Sanyo Master
  • 993 Answers
Only professional expert
Posted on Dec 26, 2014
What kind of freon does a 2002 tahoe use?
Easiest way to tell is look at the connection ports where the charging hose connects. If it has threads on the outside of the connector it's a R-12 system. If the ports have no threads then it is an R143 system.
Jul 16, 2014 | 2002 Chevrolet Tahoe
2003 tahoe alternator stops charging if i rev up to 3500 or 4000 and let it idle it starts charging
have the alternator removed and the slip rings on the rotor cleaned and machined . Replace the brushes and have the unit bench tested . When this happens it is an indication that the brushes cannot maintain contact with the slip rings either from lost spring tension --dirt on the rings and rings badly scored
Mar 02, 2014 | 2003 Chevrolet Tahoe
Wont charge
Mine is doing the same thing make sure your battery is good first to do that all you do is take out the battery beside the gold part that charges it there is a white sticker if its no longer white and if it's red your battery is probably bad witch is easily replaceable you can buy a new one on amazon or eBay but if it's like mine and the battery is still good then it probably needs a new charging port witch I'm in the process of trying to figure out how to fix or get it repaired hope this helped at least a little bit
Dec 20, 2013 | Sanyo SCP-2700 Cell Phone
When ever i try to charge my phone it wont charge. I brought a new charger and new battery still wont charge
Hello there,
Have a nice day.
You have mentioned the you have bought a new charger and a new battery but still your handset wont charge.
The problem is from the charging port on your phone. You will need to change or replace the charging port on your phone to fix the problem.
Try to take your phone to any Sanyo service center or any local phone repairer to help you replace the charging port, it has a minimum charge only.
Hope it helps,
Thank you for using the fixya.
Adieh
Sep 12, 2011 | Sanyo Incognito 6760
Usb device not recognized
Assuming a healthy camera battery, capable of holding a charge - try another cable / USB port / Computer first.
When it's same on all USB ports and a different computer, wiggle the USB connector on the camera carefully. If the connection is ok at some point, it's the camera USB port making bad connection.
Jul 04, 2011 | Sanyo VPC-X1250 Digital Camera
It won't charge anymore and I have tried different cords and different outlets.
hi, is possible the charging port is bad.. that is why its not charging..try repair the port.
cheers
May 31, 2010 | Sanyo Katana SCP-6600 Cellular Phone
Why doesn't my phone charge when i plug it in
Why don't you try to use another charger to see if it will charge with it or try to use your charger to charge a similar phone to see if it will charge it. because it could be that your charger is faulty.
But if you have try this an the charger works fine, it means the charging port of your phone is bad and will need to be change.
If the charger is good, then, just change the charging port of your phone and your phone will charge.
Take care.
Apr 19, 2010 | Sanyo PRO-700 Cellular Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
My Tahoe is having a had time turning over. the battery is charged. i took the cable off the battery and the tahoe turned off. the guy at o'reilly's put something on the battery and said the alternator was...
if your oil smells like gas you need an oil change badly. while running the alternator should be charging at 13 up to 14 volts if it's not doing that then the alternator is bad if that battery is charged and it's hard to turn over then there is a loose connection either at the battery or the starter if everything is tight lean toward the starter
Oct 23, 2009 | 1997 Chevrolet Tahoe
Charging using USB
Did it worked before? if so It can be something with the USB cable, try diff cable. USB port, try diff port. Also, you can reload the driver, sometimes it helps. It can also be that the internal fuse has possibly blown, unless you are good with a soldering iron it's not a user servicable part as such. If it never worked: Try the driver first. (the original) Good luck.
Dec 26, 2005 | SanDisk Sansa e140 MP3 Player
Sanyo Taho Scp-4100 E4100 Sprint Rugged Mil-spec Bluetooth 2mp Camera Cell Phone Logo
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
rey francis basa
rey francis basa
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
