Question about Syntax-Brillian Olevia 242TFHD 42 in. LCD TV
No sound coming out of the speakers on TV
Cable is plug in and I can see the picture but no sound.
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
Where can I plug the cable from my dvd to my Tv, so to get the sound of Tv to dvd speakers, help!
THERE SHOULD BE A RED AND WHITE CABLE WITH MALE PLUGS. U PLUG THESE ON UR AUG PLUGS OUT ON UR TV AND IN TO UR DVD PLAYER U SHOULD HAVE SOUND THEN.
Nov 27, 2014 | A D S Televison & Video
I have no sound coming out of my speakers for the reciever that is hooked up to my tv. i have 2 of the spekers hooked up and the audio cable plugged in to the tv but im getting no sound from the tv t
hi,try going into your tv setting and see if thers a setting for ext speaker as sometime ther is ,this is the place i would look and the only place i would think the fault would be ,you say audio cable i take it you mean
rca cables [two cables] if not check them but i dont think its both of them faulty,def in setting somewere.good luck
Jan 21, 2013 | Kenwood Audio Players & Recorders
I am trying to hook-up KLH pro 21 speakers to our Sylvania LC420SS8 tv, but have not been successful. Where do I plug in the speakers?
Where you plug in the speakers depends on many things like where is the source of the sound coming from? Is it a cable box? Do you want just the sound from the tv itself to come to your speakers? If you want the sound of the cable then you need to connect them to the out going leads on the back of the cable box.
The tv probably has a small button some where on the back to use external speakers. If your running the cable signal into the tv, turn on the external speaker option and then use the out going leads to send the signal to your speakers. There may also be a signal input/output choice in your tv settings. click on the different choices of in put to see if you hear through the speakers to figure out which one is for them. The choices are usually listed as AUX, Antenna 1, Antenna 2, ect.
Jun 18, 2011 | Sylvania LC420SS8 LCD TV
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
Can my tv play sound through tv and speakers?
There should be an Output in the back of the TV. You will need to get an RCA cable which is the Yellow Red and White cables. Connect the yellow and white cable to the Output in the back of the TV and connect the other end to the Speakers.
Feb 02, 2010 | Insignia IS-LCDTV32 32 in. Television
I have connected my macbook to the tv via VGA cable...i have the picture displayed, but the sound is still only coming out of the macbook speakers. How do i get the sound to come from the tv??
Connect the sound output (head phnone or line) of the laptop to the component input for sound on the TV. You will need an 1/8" plug to sterio RCA adapter to connect.
Oct 02, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Where to plug in the home theater on the tv?
If you REALLY want to plug your tv into your home theater system there should be rca (red and white) jacks on the back of the tv that say "audio out" or "speaker out" thats your tv's audio output. which is where you would plug in the TV to your home theater system.
But there's really no reason to do this and its not the most desirable way to set u a home theater. Sound doesnt come from your tv, and therefore your tv shouldnt be plugged into speaker (unless you have old school wal cable) sound comes from your cable box, DVD player, VHS, Xbox, Ps3 etc. the sound comes from your source, and these sources should be hooked up directly you your home theater reciever
Oct 01, 2009 | Dynex Televison & Video
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
24 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
