Securteycameryin a creditcard
I need a small camera to check on some one that's trying to open my door
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
Go to accesories shop their are many
Posted on Mar 25, 2014
My fuji S7000 automatically shut down (Switched off) frequently while I am taking pictures. Let me know what is the problem?
If the batteries are OK, then the shutdown has a simply-cured physical cause. Open the CF card door and look for a small square opening at the bottom of the door. Look inside this and there should be a small plastic 'plate' or flap. DO NOT TRY PUSHING IT WITH A PENCIL OR NEEDLE etc. The bad news is that if you DO see that flap inside the little square opening, then your problem probably lies elsewhere. But if what you see looks like the tip of a pencil, then THAT'S your problem. The flap is there to keep dust out. It's thickness is needed so that closing the door operates the switch. Without it, the door seems to be open and the camera shuts down. If you can find an alternative for that small plate, your problem should be solved. One solution is to attach a small (about 3mm square) piece of foam pad to the tip of the protrusion inside the square. A typical example for this type of foam pad is what scrapbookers fasten photos into their albums. There will be other solutions - but the loss of that flap will be the cause.
Mar 14, 2011 | Fuji FinePix S7000 Digital Camera
States battery door is open but it isnt
  1. open the battery door
  2. look inside you will find a small switch
  3. if the door does not reach this switch the message will be displayed
  4. try to lock it by a scotch
Dec 05, 2010 | Olympus Stylus / mju 1060 Digital Camera
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
Disk door will not open
Point an hair phone to the camcorder for 5 minutes, it might be moisture build inside, then try to eject.....and voila' the door open now.
Mar 17, 2009 | Sony Handycam DCR-DVD201 DVD Camcorder
Stuck battery/ScanDisk card
Unfortunately, you have to force the battery door (very carefully) to open it, and find what is wrong with it.
It is more likely that when closed the battery door, it was forced and it slided out of one guide channels.
You need to practice a little bit before to try it with force (genlty but with firm force), but the only way to do it is slide the button to open it, and at the same time slide to the side and pull the battery door, everything at the same time. Try it until you are able to open it.
Using any kind of tool (such a plastic pry tool, a small screwdriver, etc) to force will leave marks in the housing, and it's very possible that the plastic locking tabs will break, causing that you will open it, but unable to close properly again.
Best regards,
Mar 10, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
I can't open the battery door
Look carefully at the camera body. A symbol (small arrow) is embeded there for open the battery slot. Try it.
Nov 27, 2008 | Fuji FinePix S1000FD Digital Camera
The Battery Door on my Sony Cybershot DSC-S40 won't open.
No easy solution except:
1. Remove all 3 screws from body.
2. Carefully wedge off the back half of body.
3. The back half is connected to the front half by a small cable. Don't break this!
4. The door has a hinge pin. Wedge up and remove this pin.
5. With small screwdriver, wedge off the door from top. Should pop out.
6. Apply small amount of oil on sliding areas.
7. Reinsert door. If still stuck, see step 5.
8. Reassemble camera back and screw down.
9. The reason for sticking is unknown, but door can still be removed by popping off as in step 5.
Nov 08, 2008 | Cameras
Sony cybershot dscw50
Try and change the memory card. One of my cards had messed up and my camera wouldn't turn on
Apr 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Card-cover open
Look for the switch on the memory card door of your camera. Usually a small piece of plastic on the door closes the switch when the door is closed. Check to make sure that the plastic piece is not worn down and is making contact with the switch. You can confirm that this is the problem by powering on the camera while closing the switch manually with a toothpick. Make sure you keep your fingers clear of the extending lens while doing this. If the plastic is worn down or broken off, try attaching a small piece of scrap plastic with super glue.
Dec 16, 2007 | Olympus C-7000 Zoom Digital Camera
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
