Question about GolfBuddy 2012 Golf Buddy Voice GPS Rangefinder
Battery life only last a few holes then shuts off
Need gps to last longer than 2 to 3 holes
Tomtom
My 2 year old TomTom gps Via 280 will suddenly not turn on
Jan 16, 2014 | Tomtom GPS
It keeps freezing and battery wont charge
Usually when the battery doesn't hold a charge anymore (even if you've plugged it in to a power source for quite a long time), the device will not longer work ... i.e. it freezes or shuts down. That's because the GPS uses power from the battery and not from the AC power source (that is plugged in and charging the device).
Replacing the battery may bring it back to life ...
Aug 26, 2013 | Tomtom GO 720 GPS Receiver
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Wont power up
The nuvi 200W is an older unit and it may be possible that the battery has run it's life out.
The average life span of a GPS battery is 2-3 years and possibly a bit longer depending on different factors such as climatic conditions, amount of usage, etc.
Nov 23, 2011 | Garmin nuvi 200W GPS Receiver
My batteries don't seem to last more than 4 hrs on my Garmin. Why?
if you are using an automotive unit it shouldn't last longer than that reason being is that you always have a readily available power source.
if you are using a handheld unit (hiking, etc.) with rechargeable batteries then you might need to replace the batteries.
there are a couple of ways to prolong battery life.
1: turn the brightness down in the display settings.
2: turn the volume down of the unit
Apr 27, 2010 | GPS
Battery Life is VERY short. refuses to last longer than 10 minutes on its lowest power setting. Why is this happening? Does this happen with them all?
No generally Sony VAIO battery should last upto 1.5-2 hrs ..So your battery needs to be replaced ...
Thank You..
Dec 03, 2009 | Sony VAIO VGN-N250E/B Notebook
Garmin 1390T Won't turn on - Unless Plugged in car lighter
theb battery is faulty or has not received a proer charge time to allow it to run. If after charging for a longer time 5-6hrs it still plays up return it for a replacement or warranty repair
Jul 19, 2009 | Garmin nuvi 200W GPS Receiver
Computer dies
batteries normally last for a year or 2. if you have a 1 year old battery, the life will get shorter and shorter so if you want longer hours, get a new battery.
May 13, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Camcorders that run on 3 AAA bateries, how long do the batteries last????
I assume we're not discussing the Sony DSC-W55 since that doesn't use AAA batteries.
The battery life varies depending both on the camcorder and the type of batteries. In general, lithiums will last longer than alkalines, which will last longer than a single charge on NiMHs. On cameras that give you the option, you'll use less juice shutting off the display and using the viewfinder. Many manuals will give you estimates of battery life, but these are estimates only, the battery life also depends on how YOU use your camcorder.
Dec 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
GolfBuddy 2012 Golf Buddy Voice GPS Rangefinder Logo
42 people viewed this question
Top GolfBuddy Optics Experts
ka4iup
ka4iup
Are you a GolfBuddy Optic Expert? Answer questions, earn points and help others
