Need a new cable for my 593500-a
Where can i get a replacement cable?
  • 76 Answers
The connector type is USB micro-B
here's an example: http://www.newegg.com/Product/Product.aspx?gclid=CIqU14C1sL0CFahlOgod8iQAUQ&Item=N82E16812422983&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-USB+Cables-_-N82E16812422983&ef_id=6SFO2O@u-1gAAEqN:20140326143040:s
Posted on Mar 26, 2014
How do I change the throttle cable on a Mantis Tiller SV6 engine?
It depends on the replacement cable. If you see the plastic parts on the new cable, then you don't need to retain them from the old cable. If the new cable does not have the plastic parts, you will have to swap in your old plastic parts onto the new cable.
I hope this helps,
--Robert
Oct 28, 2014 | Mantis Garden
Cable replacement on six-sheet crosscut shredder Executive Machine EPS-611X?
Fairly simple fix then; figure out what length of cable you need (or would like to have if you need something a little longer (like 1 or 2 feet more)) and run down you your local hardware outlet; a place like Lowes, Home Depot or Ace Hardware and pick up a 2 or 3 wire replacement. Make sure it is th same guage wire inside. This will involve opening the unit to install the new one. Take the head unit off, open it and see where the wires from the cable attach to. Make a drawing or take a picture of it before you take things apart and along the way so that reassembly with be easier. Disconnect the old broken cable, and connect the new one. If it is solder to a circuit board, or soldered to the switch, cut the wire back (the old one) so that you can splice the new cable to it. If it uses little connectors, you can disconnect it, and take them along when you go to get the new cable and see if they have similar connectors you can use on your new cable. Reassemble it, and test it. Should be a pretty simple fix. Let me know how it comes out. If you need any additional help, just post it here. -Coss-
Dec 10, 2013 | Executive Machines SESS640HD 6-sheet strip...
Toshiba 593500-A ok on windows 7 but not recognized by windows XP
after you turn on laptop or computer, enter BIOS (pressing key for it ... depends from models of laptops, for computers is DELETE, for toshiba laptops is F10 etc.) and change sata mode from AHCI to any other available and try installation of Xp then
Oct 18, 2013 | Computers & Internet
My toshiba 593500-a external harddrive isnt detected
hi i dont know how old this post is??
but right now iam having the exact same problem the only curious thing is that it works on MAC but not on PC, any help please?? or did you find a solution ???
thanks a lot
Jan 14, 2012 | Computers & Internet
My system makes a buzzing noise while it is playing, I think I need a new subwoofer cable because when you wiggle the cable the noise is almost gone. What do you think? Where can I get a new cable?
It might be your cable. Go to Radio Shack with the cable - and see if they will test it for you before spending money on a new one. It may be a toasted channel - in which case you may need to replace the entire unit. Good luck!
Dec 09, 2010 | Teac CD-X8 CD Shelf System
Battery problem, big cable is swolen
this is caused by battery acid intrusion, the cable ,must be replaced.
Mar 26, 2010 | 2004 Honda Accord
Toyota corolla 2007 will not roll over, but just clicks
your starter need new contacts for the solenoid. Most garages will sell you a new starter. Find a Alternator/Starter shop that can replace them for you. its a lot cheaper than a new stater.
Oct 12, 2009 | Toyota Corolla Cars & Trucks
Broken the mains power cableand dont know were to get a new one
Help is at hand. but you do need basic electrical skills for the first solution and handy soldering skills for the 2nd.
sol1
If you cable is fraid then cut the cable and fit an inline connector. If your not sure here is a link.
http://www.4barmey.co.uk/cgi-bin/product.pl?PID=1078065&item=783496&section=67924&path=67885,185197,67893:185866,67924
Sol2
Total replacement of power cable and plug. you will need to buy new flex and plug. normally two core flexible (multicore not solid core) cable.
Open up the rear case to the tv and keep all screws. DO NOT touch the end of the tv tube as high voltage lingers a while after unplugging. You are looking / tracking the power cable where it fits to the tv motherboard.
Take a standard solder iron and remove each cable in turn. noting the colour and positions. Prepare your new cable feeding it into the casing and motherboard to suit. Apply flus and solder to secure each new cable in place. Hold cable while it sets and cools. CHECK there is no solder connecting these cables together for obvious reason these DO NOT connect together.
Replace casing and all screws in reverse order.
You should have a good to go new cable and a tv working fine.
AndystUK
Aug 31, 2009 | Crown Televison & Video
Need a replacement screen, its cracked any chance on getting a replacement, is it worth replacing?
Hey how are you!!!
What is your unit? If your unit is a laptop ou need to follow this.
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no back light.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the back light inside the old screen lights up, apparently the new screen has defective back light lamp and has to be replaced.
Good luck
ICmanServer
Aug 14, 2009 | Memorex MM7000
Computers & Internet Logo
David Payne
David Payne
